Parkway 142 #1 Posted November 19, 2018 I’m a fairly new pilot, and seem to be struggling with the use of “affirm” and “roger”. I understand the meaning of both, and the context in which they SHOULD be used, but I seem to continually default to saying affirm when I really should say roger. Has anyone else had this problem? I guess it will eventually work itself out, but I thought someone might have a way they went about drumming it into their head haha. On my last flight I did it so many times it started to become comical! Here’s a short video of it https://youtu.be/f3MJ5CGxxLY Share this post Link to post Share on other sites
kgwilson 2,059 #2 Posted November 19, 2018 "Roger" used to be the phonetic for "R" before the NATO phonetic alphabet became the standard so "R" is now Romeo. Roger is defined as "Read and Understood. I have received all of your last transmission". Affirm means "Yes". So if someone is asking you a question & you can answer with a yes, say "Affirm". It you are being advised of a situation where a readback is not required say "Roger". What is not acceptable is CB speak of "Copy" or "Copy that" etc. There was an article in the October Sportpilot of radio use in class G airspace. There is no difference when you are in controlled airspace except when being provided with information from ATC a readback is usually required to confirm you have read and understood the transmission. 1 Share this post Link to post Share on other sites
old man emu 1,906 #3 Posted November 20, 2018 Actually, the use of words that are not used in common conversations is an example of poor communication. When was the last time someone asked you if you would like a drink and you answered, "Affirm"? The use of unnecessarily long phrases, such as, 'at this point in time', 'at the end of the day' and similar is an obnoxious abuse of language, introduced by citizens of the United States of America in an attempt to give the impression of literacy. I remember way back when I was doing circuits and bumps at Bankstown and was about to taxi off the runway. ATC told me to 'expidite'. I asked my instructor what that meant and he said, "Be quick." Having to ask the question slowed my exit from the runway. 1 Share this post Link to post Share on other sites
facthunter 12,190 #4 Posted November 20, 2018 (edited) Expedite has been in use for ages . If you do something expeditiously you do it as quickly as possible. You may be cleared for" Immediate " take off and that means what it says. It's Affirmative. also for yes. These words are used to avoid conflict in meaning and for clarity. Yes is "affirmative" and no is "negative" Say again is used for repeat, sometimes. IF you are given an instruction you can't comply with you say "negative"( to that0 unable to comply "Require" alternate clearance etc.. Wilco means received and will comply. Roger has been gone for a while as is over and out. Went with the Able, Baker Charlie, Dog, Phonetics. Nev Edited November 20, 2018 by facthunter error Share this post Link to post Share on other sites
Birdseye 523 #5 Posted November 20, 2018 (edited) Roger is alive and kicking, but note that these days it only means you have received the last message, not that you have understood it! Affirmative is abbreviated to 'Affirm' to avoid confusion with negative in the case of clipped transmissions. Edited November 20, 2018 by Birdseye 1 Share this post Link to post Share on other sites
turboplanner 4,992 #6 Posted November 20, 2018 44 minutes ago, Birdseye said: Roger is alive and kicking, but note that these days it only means you have received the last message, not that you have understood it! Affirmative is abbreviated to 'Affirm' to avoid confusion with negative in the case of clipped transmissions. You wouldn't use your callsign? Share this post Link to post Share on other sites
old man emu 1,906 #7 Posted November 20, 2018 2 hours ago, facthunter said: Expedite has been in use for ages . Nev Obviously, since I first encountered it back in the early 70's. But you didn't answer my question: "When was the last time someone asked you if you would like a drink and you answered, "Affirm"?" Also, Isn't "Yes" a better word to use? It's short and does not sound like "No". Most transmissions are clipped at the beginning. "-ative" could be "affirm-ative" or "neg-ative" Share this post Link to post Share on other sites
old man emu 1,906 #8 Posted November 20, 2018 8 minutes ago, turboplanner said: You wouldn't use your callsign? That's taken for granted. Share this post Link to post Share on other sites
turboplanner 4,992 #9 Posted November 20, 2018 It's also taken for procedure. Share this post Link to post Share on other sites
facthunter 12,190 #10 Posted November 20, 2018 I don't think the abbreviation Affirm was and is correct . As I said, it's affirmative. These PROCEDURES are used for standardization and clarity taking into account having word misheard. What you say at the PUB or the table has nothing to do with it. You are lucky English is the international standard. You emphasize the first bit. IF you all make it up to suit yourselves its not helping. . Flying to be safe, requires discipline and rules. .I think R/T procedures are worse than ever these days. and with increasing traffic they need to be better not worse.. Nev 1 1 Share this post Link to post Share on other sites
turboplanner 4,992 #11 Posted November 20, 2018 That's correct FH, our terminology and phrases were developed in the blood of misunderstandings from WW2. Radio has been allowed to deteriorate into a rabble in Australia, and people will pay for it. Share this post Link to post Share on other sites
frank marriott 2,026 #12 Posted November 20, 2018 A pet hate of mine is “I have you visual” instead of “traffic sited” The term visual has always been (at least to me) I’m in VMC. Share this post Link to post Share on other sites
old man emu 1,906 #13 Posted November 20, 2018 2 hours ago, frank marriott said: A pet hate of mine is “I have you visual” instead of “traffic sited” Another wretched Americanism! 1 Share this post Link to post Share on other sites
Birdseye 523 #14 Posted November 20, 2018 3 hours ago, facthunter said: I don't think the abbreviation Affirm was and is correct . As I said, it's affirmative. These PROCEDURES are used for standardization and clarity taking into account having word misheard. What you say at the PUB or the table has nothing to do with it. You are lucky English is the international standard. You emphasize the first bit. IF you all make it up to suit yourselves its not helping. . Flying to be safe, requires discipline and rules. .I think R/T procedures are worse than ever these days. and with increasing traffic they need to be better not worse.. Nev I assure you that it was, but whether it is now is hard to say as I can't find a current definitive document. I'd actually like to see more facts from the Facthunter. Share this post Link to post Share on other sites
facthunter 12,190 #15 Posted November 20, 2018 The username is not fact teller. You have to do some work yourself and we all have more to learn.. From practical experience as a CPL in the 60's plus airline we never used the abbreviation. of affirmative. There was extensive information published about correct phraseology in Australia and the Phonetic pronunciation of all the alphabet and the numerals. provided by the DCA at the time. This was the international standard, not an Australian adaptation. Variations of procedure like "read backs " have changed, but little else.. " report (when) Visual" is a common request. traffic "sighted (and passed)" is used for clearance purposes, where no radar or such is available for confirmation. Nev Share this post Link to post Share on other sites
kgwilson 2,059 #16 Posted November 20, 2018 Here is a definitive document. http://wiki.flightgear.org/ATC_phraseology Share this post Link to post Share on other sites
GraemeK 82 #17 Posted November 20, 2018 For Oz, the AIP is the definitive document. And AIP GEN 3.4-25 gives it as AFFIRM. 1 1 Share this post Link to post Share on other sites
old man emu 1,906 #18 Posted November 20, 2018 I was watching this series on Youtube https://www.youtube.com/watch?v=VzbUBvKduqk It's radio communications between aircraft and Ground Control at Kennedy Airport. At one stage, a pilot does use the term "Affirm", but I have only seen that once in very many episodes of this series. Here's a Youtuber who is concerned about poor radio use. https://www.youtube.com/watch?v=u-yi5xbAhI0 Share this post Link to post Share on other sites
Head in the clouds 2,628 #19 Posted November 20, 2018 10 hours ago, facthunter said: The username is not fact teller. You have to do some work yourself and we all have more to learn.. From practical experience as a CPL in the 60's plus airline we never used the abbreviation. of affirmative. There was extensive information published about correct phraseology in Australia and the Phonetic pronunciation of all the alphabet and the numerals. provided by the DCA at the time. This was the international standard, not an Australian adaptation. Variations of procedure like "read backs " have changed, but little else.. " report (when) Visual" is a common request. traffic "sighted (and passed)" is used for clearance purposes, where no radar or such is available for confirmation. Nev I dare say there have been some changes since the 1960s. I got my CPL in the 1980s and I never heard of Affirmative, it was always Affirm. Over and Out are still in use (never used together of course) but mainly for HF rather than VHF. Though in cases of poor VHF reception such as was the case on the far north coasts until 10yrs or so ago, they can still be helpful for understanding. Roger is still in everyday use, as is Wilco. Here is a link to the AIP - see pages 293 & 294 (Gen 3.4 - 25 5.) This is the current version issued a few days ago. A few extracts - AFFIRM Yes. NEGATIVE No or Permission is not granted or That is not correct or Not capable. OUT This exchange of transmissions is ended and I expect no response from you {not normally used in VHF or satellite communication). OVER My transmission is ended and I expect a response from you {not normally used in VHF or satellite communication). ROGER I have received all of your last transmission [under NO circumstances to be used in reply to a question requiring READBACK or a direct answer in the affirmative or negative). WILCO I understand your message and will comply with it. 1 Share this post Link to post Share on other sites
facthunter 12,190 #20 Posted November 20, 2018 (edited) If it's in the AIP it's official . The date of that would be of interest. Over is used in poor communications only if needed like scratchy HF . Nev Edited November 20, 2018 by facthunter More. Share this post Link to post Share on other sites
Head in the clouds 2,628 #21 Posted November 20, 2018 14 minutes ago, facthunter said: If it's in the AIP it's official . The date of that would be of interest. I did provide the link so anyone could check, and said "This is the current version issued a few days ago". The date of its release was 8th November 2018. The previous versions have had the same information for Phraseology as long as I can remember. Affirm, for example, goes back to at least the mid 1980s. Share this post Link to post Share on other sites
facthunter 12,190 #22 Posted November 20, 2018 Was still an active topic of discussion in 2006 (12 years ago) in international aviation circles with high time Air Traffic Controllers still saying "Affirmative" is correct at THAT time in the USA which may still be that way.. Affirm and affirmative are not entirely the same words. Many think one is a shortened version of the other when it is not. Russia has used affirm for a long time but that's where you are required to use English as the standard in International Flights. Nev. Share this post Link to post Share on other sites
Head in the clouds 2,628 #23 Posted November 20, 2018 29 minutes ago, facthunter said: Was still an active topic of discussion in 2006 (12 years ago) in international aviation circles with high time Air Traffic Controllers still saying "Affirmative" is correct at THAT time in the USA which may still be that way.. Affirm and affirmative are not entirely the same words. Many think one is a shortened version of the other when it is not. Russia has used affirm for a long time but that's where you are required to use English as the standard in International Flights. Nev. That's probably where you got the Affirmative from, it's not been used in Australia for at least 35yrs, if at all, but it's always been used in USA. This discussion is about Australia of course. From AIP (FAA) Gen 1.7-15 (2016) - AFFIRM U.S. has no phraseology using “AFFIRM”. U.S. uses “AFFIRMATIVE” “Yes”. ; or “ACKNOWLEDGE; or Roger, Wilco.” Share this post Link to post Share on other sites
IBob 612 #24 Posted November 20, 2018 Just be sure to get an Affirmative before you Roger...) 1 5 1 Share this post Link to post Share on other sites
facthunter 12,190 #25 Posted November 21, 2018 Why do you say IF AT ALL. ? The change appears to have been around 2006 in AUSTRALIA.. and I worked as a full time airline pilot for 25 years. and always used Affirmative Never Yes, Roger,, Over or Out. Plenty of Australian pilots operate internationally. Nev Share this post Link to post Share on other sites
