cespal2
Painting or Wrapping?
Has anyone had experience with wrapping an aircraft. It looks like is is becoming more popular with very good results.  I am building a Savannah and was thinking about getting it wrapped, not because its getting close to xmas.
What is the difference in price between the two and also the pros & cons?
If you decide to wrap let us know how you go time wise, you can buy the wrap off alixpress for about $300-$400 and you still need to prime the surface to get the wrap to stick
Protruding rivet heads may make it difficult to get the wrap to stick around them. Any voids under the vinyl might become a corrosion trap?
That's true if done poorly. However, vehicle wrap is a different product to the vinyl used for making rego letters and stick on graphics. Vehicle wrap is very flexible and is applied using a heat gun. With care, the rivets can be dealt with effectively, but it will be a very tedious job.
In addition to that, you could have a very speccy "paint job" for a lot less than having it painted that way. And if you come to dislike the decoration, you can heat it off and design a new one.. But you'd still have to prime and paint a base coat, probably white would be best.
Would it be more tedious that epoxy filling and sanding all the rivet heads as I have already done? I am thinking that would be a good start to getting a good wrapping result but I would still be a bit concerned about the weight difference between wrap and a conservative layer of paint.
Ok, just did a little research.  According to 3M, their 1080 vehicle wrap is approximately 150g/sq. metre.
Then watched a youtube video where a bloke does a before and after weighing of a square foot of bare metal, painting it with primer, 3 coats of colour and 3 of clear.  It came out at 26 grams, given there's 10.8 square feet to a square metre, that's 280g/sq. metre.
Obviously the plane won't be given the full car paint so you could probably halve that, which makes it pretty even.
Ok, so maybe the same weight as a full paint job.
750 being wrapped - doesn't look like they primed this one.
Wrap vinyl requires a gloss surface for maximum adhesion.. . . . for some reason, they won't guarantee full adhesion to a bare metal surface.   Contact a Spandex representatiive  ( USA ) or one form HEXIS ( France ) for technical spec on wrapping materials.   Car wraps are based upon a Gloss substrate in all cases that I have encountered.  So I would assume that the same applies to ANY surface. . . There may be problems with bare metals, perhaps due to possible adhesive reaction between the bare metal and the Adhesive used on the vinyl material.   I am not in any way a specialist in this regard, . . .I just FIT the stuff. . .
If you have to coat the airframe with a Gloss Primer first, then wrapping it afterwards will create additional weight.  This is why all Evektor Eurostar U/L aircraft in the UK ( Sport Star Lookalike ) cannot be fully painted, as this would take the critical weight over the 450 Kg limit for Microlight  aircraft.
Edited by Phil Perry
typo / grammar
I just listened to a Matt Hall speach on Saturday.
He removed paint from his Red Bull competition aircraft and replaced it with "wrap". Saved many kilos he said.
My Jodel's fuselage has developed a few cracks and is in need of a repaint. I had planned on rubbing it back to bare plywood and applying a thin coat of S-glass before reprinting.
Maybe a vinyl coat would do both jobs in one. Any advice welcome.
