danny_galaga
ra aus 10- prefix. still used?
Posted (edited)
as per title, is this still a thing? If so, does it only apply to 'microlights'?
oh, and also can you try for a specific suffix like like you can with VH?
Edited by danny_galaga
Posted (edited)
Yes.  95.10 aircraft can be registered with RAAus or HGFA dependant on type.
home built single seaters limited to 300kg mtow and 30kg/m at mtow are not terribly popular ... particularly as you’re not allowed to put kits onto that series unless the kit has been preapproved by RAAus/HGFA ... and I don’t think any have.
basically  you can register a single sweater from a kit or home built in 95.55 and have 19 reg with more flexibility or under 95.32 with 32- reg so very few use 10- for new builds.
The only real benefit of it is if you wanted to build a very light single seater jet or multi engine ultralight as the single engine propellor driven limits do not apply to 10- but do to all other RAAus series.
On number sequence - all RAAus aircraft can have personalised numbers so long as they are not already used.  RAAus will charge you extra to get it allocated but it’s a possibility
Edited by kasper
no probs. I thought it would be something along those lines. Just turns out that the number I wanted to use would look even better prefixed with 10- 😄
But the plane is not in that category so 19- it is
Be aware that once registered in ANY RAAus registration sequence it cannot be changed after.  If you want a specific number - and it’s available - you have to build the plane to get that number.
In RAAUS registration is for the life of the airframe
1 hour ago, old man emu said:
Can you reserve the number like you can with CASA?
Yes.  Once you have advised RAAus of the build and it’s underway you can reserve a number ... for a fee ... and it’s an annual fee to maintain it until you finish and register.
Well, I can’t imagine you’d want to change a number on your plane once you have it, whether you picked it or not so that won’t be a problem:)
I saw a plane the other day with only three digits. The owner explained it was because it ended in zero (or was it beginning with zero?)
anyway, if you have a number like that, would I be right in assuming you could still display all four digits if you want?
Ops manual 4.02
ICAO group method is the preferred means for expressing a four digit call sign. Group form is the pronunciation of a series of numbers as the whole number, or pairs of numbers they represent rather than pronouncing each separate digit. The use of group form may, however, be negated by four-digit identifiers or the placement of zeros in the identifier.
Examples:
Lightwing 0437 Tecnam 1346 Trike 1215 Aerochute 1001
= “Lightwing, zero four thirty-seven.” = “Tecnam, thirteen forty-six.”
= “Trike, twelve-fifteen.”
= “Aerochute ten zero one.”
I probably wasn’t clear. The rego painted on the side of his airplane was something like 19-438
when I asked why it was only three digits he said it began (or ended, can’t remember now) with a zero so it didn’t have to be painted on. My question is- if his rego was 19-0438 is it the case you can paint the zero on if you desired?
Also, which is it that you would only
need 3 digits? 0438, or 4380? If the latter then I don’t have to worry because the number I’m hoping to get ends with a zero, not begins with a zero
I think this guy might be having a lend of you. Section 5.1, 10.2 in the RA tech manual states that the 2 digit prefix, hyphen then the 4 digit rego must be displayed
25 prefix, early ultralight. Probably old rego or has an exemption, either way long before I started flying.
Until tech manual 4 the leading 0 was not required to be displayed so 25-0125 could be 25-125
and in addition before tech 4 the 10- did not need to be displayed so 10-0125 could be 125 on the airframe.
all of this changed with tech 4 with no leading 0 exemptions and a requirement for 10- display. BUT all aircraft on the register at the date of tech 4 got grandfathered rights to display but you could choose to comply if you wanted.
And if if you were one of the one airframes registered in 95-10 after the removal of display requirements in the ops manual but before they corrected the errors in tech 4 on display you have no obligation to display ANY rego marking on the airframe and that right was grandfathered.
So so if you see a little yellow trike flying around without markings displayed just listen for the radio if I am using it because I’m legit no rego display and I choose not to voluntarily comply.  👍
