Guest The Bushman Posted September 12, 2009 Share Posted September 12, 2009 Hi Has anybody connected there Garmin 296 Audio to the Microair Radio Audio input Iam told you need to reduce input from GPS ??? James Link to comment Share on other sites More sharing options...
Guest The Bushman Posted September 16, 2009 Share Posted September 16, 2009 Garmin Connection To microair Radio come on you blokes I thought I would be swamped with the Answer ?? James Link to comment Share on other sites More sharing options...
jetjr Posted September 17, 2009 Share Posted September 17, 2009 No, but isnt the audio input designed for MP3 etc? In which case higher signal from GPS might be too much. Ive found the Alerts from 296 a bit random too, usually alerts arrival, decent etc etc, but not for every location. Also I can hear the alerts over the engine and with headsets on!! JR Link to comment Share on other sites More sharing options...
Guest The Bushman Posted September 17, 2009 Share Posted September 17, 2009 Gps Microair Yes it is to connect Trannie or MP3 player but on talking to Microair there suggestion was place in line a 100nm Capaciter any takes as to :vis::faint:is this Correct James Link to comment Share on other sites More sharing options...
brilin_air Posted September 17, 2009 Share Posted September 17, 2009 James, If the audio output is too much power for the radio input, you could try joining the brown positive wire and the orange negative wire from the GPS data cable to the headset output of the radio, and see if that works. You would have to make sure that you have the correct negative and positive wires to join into that goes to the headsets. Hope this helps Brian Link to comment Share on other sites More sharing options...
Guest 1134581 Posted September 17, 2009 Share Posted September 17, 2009 James,If the audio output is too much power for the radio input, you could try joining the brown positive wire and the orange negative wire from the GPS data cable to the headset output of the radio, and see if that works. Hope this helps Brian Probable result = SMOKE Link to comment Share on other sites More sharing options...
