Guest peterf Posted February 21, 2007 Share Posted February 21, 2007 Here is a Java program that makes it easy to find first/last light and sunrise/sunset times for any date, timezone and location on the earth. http://planofile.com/jnlp/Earth/Earth.jnlp If it doesn't run, you may need to update/install Java: http://java.com/java/download/index.jsp Also shows global cloud cover. Link to comment Share on other sites More sharing options...
Wilfred Posted February 21, 2007 Share Posted February 21, 2007 Its already on the airservices site & easy to use http://www.airservices.gov.au/brief/lightbrf.asp Link to comment Share on other sites More sharing options...
Guest peterf Posted February 21, 2007 Share Posted February 21, 2007 Sorry, the title probably should have been "Yet another one of the thousands of ways to get first/last light times". Airservices doesn't seem to work for airports outside Australia, it knows the codes but can't get the times. It also doesn't give you sunrise/sunset and only gives you the times in UTC, not your preferred timezone (if that is what you want). I guess it gets down to whether you like to type in airport code or lat/lon, or whether you just want the times based on the location on Earth where your mouse is pointing. Either way, you still get the first/last light times. Link to comment Share on other sites More sharing options...
