Guest Sunshy Posted March 18, 2005 Share Posted March 18, 2005 Some time ago, I read about problems with fuel causing filters to block up, MEC's to seize etc. Has the problem been identified? If so, what caused it? And how much impact did this have on general aviation in Australia? Link to comment Share on other sites More sharing options...
Guest Glenn Posted March 18, 2005 Share Posted March 18, 2005 All I know is that there was a fuel contamination and it grounded quite a lot of planes. Hopefully someone can fill in the details more. Link to comment Share on other sites More sharing options...
Guest Ultralights Posted March 27, 2005 Share Posted March 27, 2005 if my memory serves me, the fuel contamination issue was with fuel being supplied being contaminated, it was contaminated at the refinery, and the contaminate caused rapid corrosion of Brass that came into contact with it, and as internal components of fuel pumps and pressure guages were brass, they quickly desintergrated clogging fuel filters. not to mention damage to injector nozzels and other parts of the fuel system.. Link to comment Share on other sites More sharing options...
Guest davo Posted May 13, 2006 Share Posted May 13, 2006 I think I remember a few details: The contaminant was ethylene di-amene (EDA). It was introduced into the fuel supply apparently due to a change in fuel production methods by Mobil at their Altona plant back in 2000. EDA interacted with the metallic components within aircraft engine and fuel systems during which it changed form and a black soot-like residue was deposited. It was later established that this residue was water soluble and after much testing a de-tanking and washing regime was developed to allow aircraft fuel systems to be cleaned and returned to service. It grounded over 5000 GA aircraft for many weeks whilst the root-cause was found and the problem resolved. Davo Link to comment Share on other sites More sharing options...
