Morgan sierra 100
Messages
30
Ratings
32
Country
Country
Hi Pylon
Yes we have read that on servo and anti servo trim system , our trim system is set up such that the trim tab moves independently of the elevator as such the elevator can move through its full range of movement without altering the position of the trim tab relative to the elevator , the trim tab is controled with a ray allen servo and is controled with trim adjust in the cockpit
cheers Craig
Messages
30
Ratings
32
Country
Country
I see the lower cowl is attached to nose bowl ,bad move as you will need to remove prop to service engine,have modified several cowls to overcome this oversight
Mick W
Thanks Mick yes minor oversite to say the least ,consider that sorted , this is why we like this forum good constructive critisism , { well most of the time }
cheers Craig
Virago
Well-Known Member
Messages
186
Ratings
44
Location
Port Kennedy W.A.
Country
Country
The Morgan Cheetah/Sierra was designed without an antiservo tab. I have not heard of this being a problem at this stage. There is a Cheetah in the west which has been flying for a couple of years with an R.C.Allen servo/tab and the owner is quite comfortable with that.
gareth lacey
Roko Via Gold
Messages
476
Ratings
342 12
Location
Brisbane QLD
Country
Country
Thanks John
when we fitted the wings ,we never liked the finish with a rubber to the fuse ,we used foam to form up the flare and sanded back to the shape then fibreglassed over ,a lot of work but the result was a good line to the fuse
cheers gareth
gareth lacey
Roko Via Gold
Messages
476
Ratings
342 12
Location
Brisbane QLD
Country
Country
Thanks Mark ,here is the plane finished painting and wings on spats brakes engine electrics battery in brake lines in rudder elavator trim system all in ,all bolts locked and pin marked as a final inspection hatch in and wired final decals /airbrush work later still waiting for prop from the states
interior trim is being worked on
cheers gareth
gareth lacey
Roko Via Gold
Messages
476
Ratings
342 12
Location
Brisbane QLD
Country
Country
you need to beef up the bearings on the elavator shaft,there is to much movement and trim system is better than a bungee type trim
cheers gareth
gareth lacey
Roko Via Gold
Messages
476
Ratings
342 12
Location
Brisbane QLD
Country
Country
More Progress
fuel transfer pumps in and connected , flap actuator wired in and connected all electrical wiring in through to dash area brakes system in and working rudder and brake pedals in, floor covering in ,seating is finished an interior trim all finished (leather) all paintwork finished and air brush work is being completed this weekend , numbers go on next 19-8335 prop arrives next week (fingers crossed) spats painted with graphics
cheers Gareth
gareth lacey
Roko Via Gold
Messages
476
Ratings
342 12
Location
Brisbane QLD
Country
Country
Hi Guensey
its a Prince prop tortional it changes as you ease off power coase for take off and in cruise it goes finer ( i think i have described it right) composite ,comes with the spinner and bolts and hub?
hopefully next week
cheers gareth
Compulsion
Well-Known Member
Messages
466
Ratings
252 1
Location
YGAW
Country
Country
Hi Gareth,
She looks great. I can't wait to read your report on the first flight. It looks like you guys have done a great job of building a good looking aircraft.
gareth lacey
Roko Via Gold
Messages
476
Ratings
342 12
Location
Brisbane QLD
Country
Country
thanks for that Mark ,i knew i had it axxse about , thanks John we are getting close , a few more weeks ,still looking for a test pilot and hangerage ,ANYONE out there know a test pilot we are urgently looking for someone ,and a slot at a airstrip Local to Brisbane , will keep you informed and lookout for the movie Lol
cheers gareth
damkia
Well-Known Member
Messages
594
Ratings
307 4
Location
Townsville NQ
Country
Country
cheers gareth
Jacobs Well would be the best southside, , Boonah westside (best for BNE to Ipswich area), and Caboolture northside.
All about 1hr or less from central BNE.
I think you may find someone qualified to do your test flights at any of those areas, best to do a drive-by and ask around, I would expect...
