Guest pelorus32 Posted October 25, 2007 Share Posted October 25, 2007 There was a recent discussion along the lines of "Tyabb [or insert another name] is not in the Jepps database on my new AvMap [insert another GPS] and it should be" There's a partial solution. You will have to work out the settings for your GPS but on the Garmin GPSmap 296 this is how you find places like Tyabb, Tooradin and Wallan: Press the "Nrst/Find" button - this takes you to the airports page; Press the "Menu" button and select "Set Airport Criteria"; Set that dialog to: Runway Surface "Any"; Minimum Rwy Length "0 feet"; and Check "Include private airports" and "include heliports". Press "quit" You will find that miraculously they appear - as Heliports (Coldstream, Wallan, Tyabb, Bacchus Marsh, Tooradin, Torquay) Regards Mike Link to comment Share on other sites More sharing options...
Guest Robw Posted October 29, 2007 Share Posted October 29, 2007 Ah, that is the trick! Thanks for the tip. Cheers, Rob Link to comment Share on other sites More sharing options...
