Tablet for Savannah
JerzyGeorge
Hi All,
I have discovered pretty cool place to install tablet.
It is easy to read even in bright sun ( because it is sheltered from it), does not obstruct outside view, and fuel gauge is still easy to read. Perhaps will need external GPS antenna if signal is average.
I use Easy VFR software and love it , would recommend it any time.
Please have a look at the photos
Obviously install at your own risk , the same like flying Savannah.
George
Hi George, I use the same spot on my little VGs.
I found that not having it on the front panel stop me from looking at it too often, which is a good thing.
I am using a Bluetooth Bad Elf external GPS connected to the iPad, better signal and it also significantly increases the battery life.
I like your idea of the pen holder.
Xavier
I used to have my Ipad in the same spot but found it to be hard to use in bumpy conditions also being a big guy it was difficult to use. I swapped it to the right hand side and it was also very difficult because of the centre stick. I have since converted my Sav to twin sticks and have mounted a Ipad mini in the dash using a Airgizmo mount. I am very happy with this installation but having the twin sticks makes it very easy
