Alan Posted January 7, 2018 Share Posted January 7, 2018 The Garmin 296 GPS in my 10 year old Jab 230 has developed a white flare area in the middle of the LCD. The 296 is no longer available and replacement LCDs do not appear to be available either. I have an Ipad GPS etc. which I use with a kneepad, but would like to fill the gap in the panel. So I need a replacement GPS, preferably able to fit in the panel where the 296 used to reside. Perhaps somebody else has had this problem. Any suggestions/experience etc? Regards Alan Link to comment Share on other sites More sharing options...
vic160D Posted January 7, 2018 Share Posted January 7, 2018 The Garmin 296 GPS in my 10 year old Jab 230 has developed a white flare area in the middle of the LCD. The 296 is no longer available and replacement LCDs do not appear to be available either.I have an Ipad GPS etc. which I use with a kneepad, but would like to fill the gap in the panel. So I need a replacement GPS, preferably able to fit in the panel where the 296 used to reside. Perhaps somebody else has had this problem. Any suggestions/experience etc? Regards Alan Hi Alan, Replaced my 296 with Garmin 660 in Jab 160d, great gps and fits in the same spot perfectly; Cal.. Link to comment Share on other sites More sharing options...
jetjr Posted January 7, 2018 Share Posted January 7, 2018 Sure it fits in hole for 296? Jabiru have profiled hole for 296 not a dock. Link to comment Share on other sites More sharing options...
vic160D Posted January 7, 2018 Share Posted January 7, 2018 Sure it fits in hole for 296?Jabiru have profiled hole for 296 not a dock. Well of course the 296 dock is removed and the 660 dock put it its place Link to comment Share on other sites More sharing options...
jetjr Posted January 7, 2018 Share Posted January 7, 2018 As I said, Jabiru built aircraft DO NOT use a dock, its a hole cut in panel and bracket to mount garmin mount to, it isnt square and is a profile fit around gps unit So no it doesnt fit in 296 hole. Link to comment Share on other sites More sharing options...
vic160D Posted January 7, 2018 Share Posted January 7, 2018 As I said, Jabiru built aircraft DO NOT use a dock, its a hole cut in panel and bracket to mount garmin mount to, it isnt square and is a profile fit around gps unitSo no it doesnt fit in 296 hole. Alan, l fitted the “Garmin 660 dock that came with the gps straight into the same whole in the Jabiru dash that the 296 Garmin dock came out of, fitted perfectly, hope this helps.. Link to comment Share on other sites More sharing options...
Alan Posted January 7, 2018 Author Share Posted January 7, 2018 Alan, l fitted the “Garmin 660 dock that came with the gps straight into the same whole in the Jabiru dash thatthe 296 Garmin dock came out of, fitted perfectly, hope this helps.. Thanks for your help. I had assumed a mounting clip swap would be needed as will the BNC for the remote antenna. I was surprised that Jab fitted a remote GPS antenna; with composites I would have thought it unnecessary. Regards Alan Link to comment Share on other sites More sharing options...
