mlpinaus Posted April 7, 2008 Share Posted April 7, 2008 Any body know of a licenced technician who can calibrate a transponder in Adelaide (or nearbye) ? Jabiru sell you one with j230c that is not calibrated :confused:. It is a Microair product. Marcus Link to comment Share on other sites More sharing options...
glenns Posted April 7, 2008 Share Posted April 7, 2008 I used the pilot shop at Parafield for mine. Link to comment Share on other sites More sharing options...
mlpinaus Posted April 7, 2008 Author Share Posted April 7, 2008 Thank you. Have you a name? Marcus Link to comment Share on other sites More sharing options...
quentas Posted April 8, 2008 Share Posted April 8, 2008 You could try aircraft electrical services ph. 0881823000 hangar 58 parafield If its a factory built 230 you may need to change the altimeter to a tso unit. Jabiru gave me a refund on the chinese unit. cheers Link to comment Share on other sites More sharing options...
Guest brentc Posted April 8, 2008 Share Posted April 8, 2008 The transponder is not related to the altimiter so they should be able to calibrate the encoder no dramas and should cost less than $150. I had a small transponder repair and calibration for only $120 a couple of years ago. Link to comment Share on other sites More sharing options...
Guest aircraft1 Posted April 9, 2008 Share Posted April 9, 2008 I know this but they also made the owner change the one in the plane i rent, its some rule by casa, i dont know what wouyld happen if you had a digital altimeter ? Link to comment Share on other sites More sharing options...
Guest bazz107 Posted June 9, 2008 Share Posted June 9, 2008 The tranponder Callibration, is done to AD\RAD\43 & AD\RAD\47, these AD's say that both the Encoder and the altimeter are to be checked. This needs to be done in the Aircraft as the LAME is checking the whole system to be outputing the correct Signal strenth and Altitude. :thumb_up: Link to comment Share on other sites More sharing options...
Guest J430 Posted June 9, 2008 Share Posted June 9, 2008 aircraft1 Digital altimeter is adjustable ......... if its a dynon you can calibrate it. J Link to comment Share on other sites More sharing options...
