There is a brass plug in the bottom of the Bing just fwd of the butterfly.
Does anyone know if that is just a plug that can be drilled & tapped to mount a carb temp probe?
Or does that Brass plug contain fuel or air-ways?
If so, what does that brass plug do?
Regards Geoff
Captain
Here are 2 pics of the brass plug to which I referred above .... just aft of the 2 screws and on the centreline of the carby.
Thanks Marcus.
That is me trying to get some info from those forum members as well.
I also asked the question on the Yahoo Jabiru Engines group.
Regards Geoff
  • 1 year later...
Guest DevoutOccamist
And the answer is...?
Has anyone considered posting the actual answer to the question? Or perhaps posting a link to the answer?
The brass plug is not to be drilled. The place for the temp probe is shown in the J230@YSWG thread and it works great there. It tells you eactly when you have an ice problem starting.
Do you need anything more?
Regards Geoff
I found the right thread
Wow. There are a LOT of threads matching that string.
To save others from having to search the hundreds of pages, here is a link -
http://www.recreationalflying.com/forum/showthread.php?t=127&highlight=J230%40YSWG&page=7
Specifically it shows a single picture -
http://www.recreationalflying.com/forum/attachment.php?attachmentid=273&d=1167526434
Thank you for the nudge in the right direction,
DO
