Reply to J430 posting:
I'm getting worried about the valves / guides issue, having come across an example on Matronics which I'll copy here.
The factory must know something about material changes that us field testers are not privvy to. I can smell another CAA AD if this trend continues without some proper explanation. Is it possible that valve leakage is occurring regardless of lean mixtures, but due to abnormal guide wear?
Ralph
Posted: Fri May 11, 2007 3:22 pm Post subject: New rocker arm bushings in Well, the old bushings were a teflon-coated bronze over a steel shell
(TPFE, I believe they are known as) and for whatever reason, they
failed at...or at least I discovered them failed at...273 hours. I
decided not to replace them with the original style bushings, because
I don't know the history of how these bushings hold up under the
splash-lubricated, high-pressure (the valve spring), environment they
operate in. Now to be perfectly honest, maybe nobody else has had a
problem with these bushings, but I did, so I elected to try my own
"shade-tree engineering" and put in oilite bronze bushings. In doing
so, I decided to supplement the oil that ordinarily makes its way
into the side of the standard bushings. The standard bushings are
allowed (according to my owners manual) .004"-.010" side clearance. I
did not change this, but I did drill a .093" hole vertically into the
rocker arm, at exactly the 12 o'clock position of the rocker arm.
This will allow the oil a chance to run into the hole and help lube
the bushing.
If anybody cares, I'll continue to report how I installed the
bushings. They came 16mm wide and the rocker arm is 15mm, so I
shortened them on my lathe. I had pressed the old bushings out, and
after drilling the rocker arms for the oiling holes, I drilled the
bushing oil holes a little larger, then pressed them into place,
keeping the alignment of the holes in mind. They all came out aligned
as hoped, and then I had to ream the bushings to the size suggested
in the owners manual... .474"-.475". This provides for 2-3
thousandths oil clearance for the .472" shaft. I then swapped the
rocker shafts side-for-side, to enable the new bushings to ride on
the un-used part of the shaft. I also chamfered the sides of the new
bushings to further allow oil to make its way into the oil space
provided between the shaft and arm.
I've got to further say that I don't know squat about teflon in
engine bearings...my only use of teflon (that I know of) is frying
eggs in a pan....low (relative) heat, no pressure, and the eggs taste
fine. I wouldn't have eaten eggs cooked on the teflon that was
visible inside the removed bushings...they looked like the frypan had
been attacked with a steel spatula, if you'll permit me the kitchen
analogy. : )
Again, I'm not saying that Jabiru made a mistake, maybe I just got a
lemon, and if my "fix" doesn't work out, I will have no apologies to
make. My engine is in a Kitfox Model IV *experimental* airplane, and
that's JUST what I'm doing...experimenting.
Lynn Matteson
Grass Lake, Michigan
Kitfox IV Speedster w/Jabiru 2200
flying w/275+ hrs
do not archive
