Thruster87 Posted June 2, 2015 Share Posted June 2, 2015 Now available Issue 5 of the Jabiru Engine Maintenance Manual http://jabiru.net.au/eula/eula.php?u=/Manuals/Engine/JEM0002-5.pdf 1 Link to comment Share on other sites More sharing options...
jetjr Posted June 2, 2015 Share Posted June 2, 2015 Not many changes at first glance 1 Link to comment Share on other sites More sharing options...
Diggler Posted June 4, 2015 Share Posted June 4, 2015 Not so sure about that - some are significant. Checkout the changes to recommended max oil pressure for hydraulic lifter engines. Down from 76psi to 51psi 1 Link to comment Share on other sites More sharing options...
jetjr Posted June 4, 2015 Share Posted June 4, 2015 Lifter pump up has been a concern for a long while South African agent issued an SB on this some time ago The problem is the minimum pressure if you adjust to this low, hot engine on idle youll see alarms come on Link to comment Share on other sites More sharing options...
