Akazia Posted November 15, 2016 Posted November 15, 2016 Wondering if anyone still makes engine mounts, cowls or FWF kits to suit the EA81 in a Zodiac 650. Or has any suggestions for other suitable parts, cheers Tim.
terryc Posted November 15, 2016 Posted November 15, 2016 Hi Tim, I have a engine mount for an E81 to go into an zenith 701 might be the same or similar enough to alter.
techie49 Posted November 15, 2016 Posted November 15, 2016 Hi Tim, Glad to see you're using a 'proper' engine ! My cowling came from Zenith and is listed for a Rotax 912. Depending on the mount, you may have to fibre glass two bulges for the rocker covers. I didn't need to but as I've used a Weber carb I had to put a bulge in the top instead. Paul 1
diesel Posted November 16, 2016 Posted November 16, 2016 Will depend on whether you use a redrive. Engine hight will alter. Huge power difference. Chas
Akazia Posted November 16, 2016 Author Posted November 16, 2016 Quote Will depend on whether you use a redrive.Engine hight will alter. Huge power difference. Chas Looking at an Autoflight redrive, plus some of their other options like dual port heads, efi, tuned intake & exhaust.
Akazia Posted December 20, 2016 Author Posted December 20, 2016 Quote Hi Tim, I have a engine mount for an E81 to go into an zenith 701 might be the same or similar enough to alter. Sorry for the late reply Terry, are the 701 & 601/650 firewalls/engine mounts the same.
terryc Posted December 20, 2016 Posted December 20, 2016 Quote Sorry for the late reply Terry, are the 701 & 601/650 firewalls/engine mounts the same. Hi akazia I doubt it
