Guest fly Posted May 23, 2008 Share Posted May 23, 2008 HI all, Just a simple question ??? on a T500 Thruster! Is it OK to fire up a rotax 582 on a T500, minus the wings ? Will I have any stability/ torque problems ? Thank You ......................................FLY Link to comment Share on other sites More sharing options...
Skyhog Posted May 23, 2008 Share Posted May 23, 2008 There should not be any torque problems as the wheels are still the same distance apart,however....without the weight of the wings behind the main wheels,the tailwheel will have less weight on it.You should be fine to run it if the tailwheel is tied down,rather than just chocking the mains. Link to comment Share on other sites More sharing options...
Guest TOSGcentral Posted May 23, 2008 Share Posted May 23, 2008 I concur with Skyhog's comments other than emphasising that with the weight reduction from having the wings off then the power to weight ratio will take mighty leaps forwards and a 582 is certainly going to pull you about a lot more. You must securely tie the aircraft down and I strongly advise that you do not attempt to taxi it with the wings off. Tony Link to comment Share on other sites More sharing options...
BigPete Posted May 23, 2008 Share Posted May 23, 2008 Now I'm tippin' that it will go faster on the ground without wings, (all that drag) than it does in the air!!! :big_grin::big_grin::big_grin: Sorry, sometimes I just can't help myself. regards Link to comment Share on other sites More sharing options...
Skyhog Posted May 25, 2008 Share Posted May 25, 2008 Big Pete,the thruster would need to do well over 100kts to compare with the fuel economy of my family vehicle.You maybe right in saying it could almost do that with the wings removed,but what worries me is that it has no BRAKES. Link to comment Share on other sites More sharing options...
Guest ozzie Posted May 27, 2008 Share Posted May 27, 2008 Hi all. I remember years ago in the original thruster factory a Thruster being returned for repair. Most of the cockpit and tail group had to be replace. the wings where unmarked they were still brand new. the owner decided to learn to taxi it without the wings fitted. Don't do it. ozzie Link to comment Share on other sites More sharing options...
