For those of you who are interested in what Dorothy's antique instrument panel looks like, here it is:
[ATTACH]341.vB[/ATTACH]
Just the basics- although even this has more than most. For example, oil temp and cylinder head temp guages are optional on Austers. Most don't have them. The big blanked hole on the left is where the DG used to live- but it's bearings had worn out so it just played ring-a-ring-a-rosie, and I removed it to save weight. Fixing it would probably cost a small fortune.
The big dial with the two needles in the centre (behind the throttle lever) is the turn and slip-skid indicator. I've actually flown Dorothy for about half an hour under the hood using this basic blind-flying instrument, and believe me, I have much greater respect now for those that did it for keeps back in the old days! It was hard work- and I was sweating within 15 minutes.
We have two fuel tanks, but only one fuel gauge- just visible behind the compass. It gives a rough idea of the amount of fuel in the front (main) tank (in imperial gallons) but we pay it scant attention- unless it is telling us bad news- and go by time only. The belly (auxilliary) tank has no gauge, we just run it for one hour and fifty-five minutes, or until the engine coughs- whichever occurs first.
The only other instrument is the Garmin89 GPS (just visible at left). There is only one lever- the throttle. There is no mixture control (Dorothy runs in full rich at all times) and no pitch control (fixed pitch wooden prop).
Although the placard says "Flight Manual Stowage Behind Pilot's Seat" that is a lie- there is no flight manual for this model. There is a certificate of airworthiness that gives the basic information you need such as empty weight, max gross weight, and a few other relevant bits of information. There is no "P-Chart", and no C of G chart (in its original configuration, to get it outside its C of G range you would have to overload it). I've created a C of G chart from the figures derived from a recent weighing, but little has changed- you have to do ridiculous things to Dorothy to get her outside the C of G range without actually overloading her.
So the flying is simple. Chuck the luggage in and swing the prop. If there is a loud noise coming from the front, then the engine must be running, if the wheels have stopped turning, then we have some altitude, and if it all goes quiet, we have run out of fuel...
Coop
[ATTACH]17878[/ATTACH]
