Welding is not my forte but I have done casting....
When you finally buy your dream a/c you assume every thing is set up correctly-after all the previous owner had enough confidence in it to do a demonstration flight. But is it? Reputable factory built a/c not modified by "fiddlers" should score ok but home built a/c need to be a concern. Before I bought my Varieze I researched potential problems. One builder in the USA spent four years building his Varieze but forgot to bolt down wing attachments which eventually get covered by fibreglass. Both wings fell off on his first flight. Another owner, under the influence of alcohol, crudely rebored tapered wing pin structures and then bolted them down as tight as he could [requires 3 foot pounds] He went off and did aerobatics[no no] One bolt broke away and the wing swiveled back on the remaining bolt. The winglet now produced uncontrolled yaw which flipped the plane upsidedown. His surviving relations took Rutan through an expensive court battle after which he stopped selling plans and went on to better things.
What has all this got to do with engine cooling? Absolutely nothing! However,when you buy your homebuilt or any a/c check if it has been built properly-cooling systems I find can be inadequate and it is you who will pay through the nose once you sign on the dotted line. Actually, in my opinion, all piston aircooled 4 stroke engines run in an over heated state. If a part of an engine fails as a result of too much heat rather than normal friction wear, then the engine is running too hot. Becomes part of the high cost of flying.
