eloigorri Posted November 30, 2016 Share Posted November 30, 2016 Hi I am trying to locate the Tecnam P92JS Stall warning buzzer location. Mine has stopped working and l would like to fault find. If I recall the sound comes from above. l am guessing it is somewhere buried near one of the wing roots in the cabin? The MM does not specify the location or the specific part. I figure it must be some kind of basic piezo electric buzzer 12v. Any pointers gratefully received. Ed Link to comment Share on other sites More sharing options...
johnm Posted November 30, 2016 Share Posted November 30, 2016 don't know eloigorri but its not a big task to remove the plastic cabin lining above - for a look ................... your comment re stall warning could make an another interesting topic - I'll try that in 'general discussion' - thanks Link to comment Share on other sites More sharing options...
Ayecapt Posted February 19, 2017 Share Posted February 19, 2017 HiI am trying to locate the Tecnam P92JS Stall warning buzzer location. Mine has stopped working and l would like to fault find. If I recall the sound comes from above. l am guessing it is somewhere buried near one of the wing roots in the cabin? The MM does not specify the location or the specific part. I figure it must be some kind of basic piezo electric buzzer 12v. Any pointers gratefully received. Ed You got me thinking now as to where its located on our Sierra . It wont be in our roof because thats a canopy . And i cant recall seeing behind the panel. Though that's a logical place for it. By the way you have checked the stall actuator out on the wing? They can suffer damage ( bent ) Link to comment Share on other sites More sharing options...
eloigorri Posted February 19, 2017 Author Share Posted February 19, 2017 You got me thinking now as to where its located on our Sierra . It wont be in our roof because thats a canopy . And i cant recall seeing behind the panel. Though that's a logical place for it.By the way you have checked the stall actuator out on the wing? They can suffer damage ( bent ) I found the buzzer behind the upper side panel by the pilots head, held in by two screws. The buzzer had failed. It was easy enough to change out. Cheers. E Link to comment Share on other sites More sharing options...
