Guest Daza76 Posted February 10, 2008 Share Posted February 10, 2008 Hi All, I have had mixed reports regarding the colour screen on the Garmin 296 and its readability in sunlight.. My question is, has anybody had experience using a Garmin 296 in a trike? (which I would imagine has a much greater amount of sunlight glare than in a closed cockpit aircraft). I like the extra features of the 296, but they would be useless if I couldn't see the screen well in sunlight! Would the 196 be a better option for trikes (less features but greyscale screen). Appreciate any thoughts. regards, Darren Link to comment Share on other sites More sharing options...
Guest brentc Posted February 10, 2008 Share Posted February 10, 2008 I've got a 296 in the Jab and I find it hard to read depending on the light so I think it would struggle in broad daylight. You'll find though that if you're used to it and you know what you're looking for you'll find it ok. I find when I try to get my passenger to look at it they usually put up their hand to try and block the sun and read it. It's like watching TV in a room with the blinds open in daylight. If you're sitting there happily looking at it you're fine, until someone whinges about the reflection from the windows. Link to comment Share on other sites More sharing options...
Guest RIC Posted February 17, 2008 Share Posted February 17, 2008 I use a 196 in a Airborne outback,it's wired in so no flat batteries,I've not had any issues seeing it clearly.Would you really use all the bells & whistles of a 296 in a trike, but they have come down in price which makes them mmm I wonder if I should. Cheers Ric.;) Link to comment Share on other sites More sharing options...
Guest Daza76 Posted February 17, 2008 Share Posted February 17, 2008 Thanks for your input gents, I ended up going to a GPS specialty shop where I was able to take both units out into the sunlight and I must say, I was extremely impressed with the colour screen on the 296. It has a non-reflective coating on the display which worked great in what was a very bright day, all viewing angles were fine. Needless to say I went for the 296! thanks again. ;) Darren Link to comment Share on other sites More sharing options...
eastmeg2 Posted February 17, 2008 Share Posted February 17, 2008 Hi Darren, I flew a friends trike with a 296 in it a few months back. The only issues I had were with getting used to where to look for the information I wanted, no issues with screen visibilty were noted at all. After using it for about 1/2 hour I got used to where to look and it kept getting better from there. Cheers, Glen Link to comment Share on other sites More sharing options...
Jabiru Phil Posted February 18, 2008 Share Posted February 18, 2008 The 296 is a great GPS to read. I have mine on a Garmin supplied ratchet swivel mounted on top left hand side above the panel. I find that I can swivel to a position that is perfect when the sun glare is around. Also you are looking out the window when fiddling, as you do. Phil. Link to comment Share on other sites More sharing options...
