rgmwa Posted April 19, 2022 Share Posted April 19, 2022 On 07/04/2022 at 2:50 PM, skippydiesel said: My thanks to all respondence - seems the SV-GPS-250 (the cheaper slightly less capable of the two offerings) will do all that I require from now and into the foreseeable future. The SV-GPS-2020, with the correct module, will deliver ADSB Out & In. The Dynon Skyview will allow the pilot to see ADSB equipped aircraft in the vicinity - great for VFR operations but of limited value(7 much higher cost) for the relatively low/slow Day VFR only aircraft/pilot. You also need a second antenna for ADSB-IN. Received this from Horsham Aviation (Dynon distributor): The GPS 2020 will provide you with ADSB out functionality, however for the system to function correctly you require the following: ADSB in: 102985-000 SV-ADSB-472 102629-000 SV-HARNESS-ADSB 102608-000 SV-TRANSPONDER-ANTENNA ADSB out: 101409-000 SV-XPNDR-261 102558-000 SV-HARNESS-XPNDR 102608-000 SV-TRANSPONDER-ANTENNA 1 Link to comment Share on other sites More sharing options...
