digistore Posted April 24, 2008 Share Posted April 24, 2008 Does anyone have a PDF or other soft copy of the aircraft flight manual? Tim Link to comment Share on other sites More sharing options...
Guest Macnoz Posted April 27, 2008 Share Posted April 27, 2008 here you go say thanks john http://www.flugschule-klv.at/klv/manual-P2002JF.pdf Link to comment Share on other sites More sharing options...
digistore Posted April 27, 2008 Author Share Posted April 27, 2008 Sierra manual Thank you for this. Much more comprehensive than the photo copied one the owner has! I will print one for him as well. Tim :big_grin: Link to comment Share on other sites More sharing options...
Guest pelorus32 Posted April 28, 2008 Share Posted April 28, 2008 Thank you for this. Much more comprehensive than the photo copied one the owner has! I will print one for him as well.Tim :big_grin: Hi Tim, might be worth being aware that the P2002 and the P2002JF are similar but not the same aircraft. The JF is the certified version I think. I think this kind of issue is referred to in Mick Poole's column in the most recent RAA Mag. I think he says something like "don't assume the numbers are the same with similar aircraft" - and then gives a Jab example. You should not rely on the manual until you have ascertained that it is the same between the P2002 and the P2002JF. Regards Mike Link to comment Share on other sites More sharing options...
digistore Posted April 28, 2008 Author Share Posted April 28, 2008 2002 vs 2002 JF Yes I was wondering about that. MAUW for example. However I think the majority is the same but I will check against the photo copy version the owner has. Tim Link to comment Share on other sites More sharing options...
Bruce Posted April 29, 2008 Share Posted April 29, 2008 All the figures for the P2002 airframe are esentially the same but MTOW 580 kg for the JF and 600kg for LSA airframe. Other main difference is that the Tacho of the JF is cable driven and gives propellor rpm whereas the LSA Sierra tacho shows engine rpm. If referring to the P2002JF manual you should multiply the rpm settings given by 2.431 to get comparable rpm settings for a P2002 Sierra. Regards Bruce Link to comment Share on other sites More sharing options...
