Bandit12 Posted January 18, 2012 Posted January 18, 2012 Hi All I've been toying with the idea of homebuilding for quite some time, and really need to get along with it. I like the idea of the 95.10 framework, and also of a minimal aircraft. Can anyone tell me whether it is possible to fly a 95.10 aircraft to more populated airfields, which would require flying over populated areas? The guidelines seem to suggest that it isn't normally permissible, but that it may be possible with permission. I was wondering if anyone actually ever has? Also, whether anyone has any suggestions of plans built aircraft? Cheers Shane PS there seems to be a few familiar faces around here!
Teckair Posted January 18, 2012 Posted January 18, 2012 Quote Hi AllI've been toying with the idea of homebuilding for quite some time, and really need to get along with it. I like the idea of the 95.10 framework, and also of a minimal aircraft. Can anyone tell me whether it is possible to fly a 95.10 aircraft to more populated airfields, which would require flying over populated areas? The guidelines seem to suggest that it isn't normally permissible, but that it may be possible with permission. I was wondering if anyone actually ever has? Also, whether anyone has any suggestions of plans built aircraft? Cheers Shane PS there seems to be a few familiar faces around here! Yes it is possible, happens all the time, but not legally, if something goes wrong bad news. A friend of mine is building a Affordaplane check that on the nett. Regards Richard.
robinsm Posted January 18, 2012 Posted January 18, 2012 I fly a kit built 95.55 aircraft, rag and tube with a 2 stroke Rotax motor. I applied for, and received, written permission to fly over built up areas from Raa-Aus. Contact the powers that be and ask them.
