912uls Hoses
JUSTNUZZA
Can someone advise me on what brand fuel and oil hoses to use on 5 year replacement that are not part of the Rotax system. Example oil hoses to oil cooler and fuel hoses to gascolator ? I know to use the kit from Rotax for the rest of the rubber replacements.
You could try pirtek (google it) you have to make sure the temp & max pressures are right for your application
I'm using oil hose to cooler ,the hose is rated to 125c & 250 psi .
I found a lot of oil hose was only rated to 80c & 250psi . I found pirtek have good range of fittings as well , I ended up going with the alum push lock fittings for oil as well as fuel .
I assume these figures are max temp at max pressure .My application is a 3300 jab.
Hope this helps
Cheers mike
Sorry Ian, Thread should be in engine and prop section.
Goss fuel hose outlasts Mackay by about 12 months. Best option is to get aircraft-quality 1/4" fuel-hose - it will last 5 years. Automotive hoses are good for about 12-15 months at best. Try Aircraft Spruce & Specialty for aircraft-grade fuel-hose.
