Lightwing981 Posted October 24, 2016 Share Posted October 24, 2016 I recently borrowed a Dynavibe to balance my prop. It worked well and I am looking to buy some type of dynamic balancer. Firstly, does anyone have any experience using the UK PB-3? They are about half the price. One negative is the use of an android interface with wi-fi. Also are there any used Dynavibes out there for purchase? Link to comment Share on other sites More sharing options...
Thirsty Posted October 25, 2016 Share Posted October 25, 2016 I have a PB-3 -works OK with the Android interface - I just bought an el cheapo mobile and use that. Link to comment Share on other sites More sharing options...
jetjr Posted October 25, 2016 Share Posted October 25, 2016 I bought one too, way more flexible than dyna vibe Hardly used it though Can you outline process Thirsty? Link to comment Share on other sites More sharing options...
Thirsty Posted October 25, 2016 Share Posted October 25, 2016 I could but too busy at work :) If anyone is interested here is a link to the app user manual http://www.smartavionics.com/pb3/PropellerBalancerManual.pdf Some good general interest reading there about the process. Link to comment Share on other sites More sharing options...
Bruce Tuncks Posted October 25, 2016 Share Posted October 25, 2016 Don't do what I did and overheat the engine. I was running it at cruise revs on the ground for the dynamic balancer and lost an exhaust valve seat. While I still agree with dynamic balancing, next time it will be set up to work during flight. I'm thinking of a simple vibration meter, but one which was specific to prop speed and which also showed phase would be better. Link to comment Share on other sites More sharing options...
jetjr Posted October 25, 2016 Share Posted October 25, 2016 The PB3 should be able to do that, Just need to watch temps for the tach and wireless unit I had a nice little bracket made up to fit sensor to top of oil pump.......by CAE long ago Link to comment Share on other sites More sharing options...
Lightwing981 Posted October 26, 2016 Author Share Posted October 26, 2016 I have a PB-3 -works OK with the Android interface - I just bought an el cheapo mobile and use that. Hi Thirsty, thanks for that. It seems to have some more features. Should be same accuracy. Link to comment Share on other sites More sharing options...
DonRamsay Posted October 26, 2016 Share Posted October 26, 2016 I had my prop balanced by Keith Baker using some fancy gear but not sure what it was. My prop was not bad but it was brilliant by the time he finished. While it's good for a Rotax it is even more important for a Jab as it balances the entire drive train - engine & prop. It can identify issues with the engine if the prop can't be balanced. Link to comment Share on other sites More sharing options...
mlpinaus Posted October 27, 2016 Share Posted October 27, 2016 I had James Hubbard at Murray Bridge give 7595 , my j230 , a dynamic balance too. The results were impressive. Smooth is the word. I would swear that there is more power too......... Marcus Link to comment Share on other sites More sharing options...
