Hi All
I am putting it out there to see if anyone has a aileron rigging jig for the CA25 Skyfox gazelle?
Physical one i can borrow, a set of drawings to make one or a lead on more info?
  • 2 weeks later...
Hi Thanks
I don't suppose you had a drawing or some measurements?
Straight edge is fine just the curve i am really after.
  'smokey487 said:
Hi Thanks
Have the straight edge timber or even alloy and attach the end piece and cut a rough curved shape then fit under wing a little off and hold a marker a distance behind the aileron and move it go through full deflection travel of aileron and cut out the line and that's it.  I used shock cord over the top of wing to hold it on.
 You only need to locate at the leading and trailing edges Can't you use levels a or a laser ? Once you test fly it you will probably adjust it a bit anyhow. Nev
