Taking off yesterday (after 2 touch and goes) from a full stop I head a clunk under my seat, immediatly cut throttle and put her back down on the runway (I have 1.4km to use).
Taking off the  covers over the main landing gear I note that the left hand rubbers are pretty much done, so easy, order new ones and replace (and do the 500 hr update while I am there).
My questions is, on the right hand side there is a white spacer that sits above the inboard bolt, about 10mm in height. It is only on the right hand side, the left hand is hard against the floor.
I can't see this spacer in the Jabiru Technical Manual for the J160 airframe.
Reaching out to the brainstrust here, is this supposed to be there? Should there be one of the left hand side as well or should I remove it when I replace the rubbers?
I am going to do a wheel alignment when I finish as I am chewing out the outside of the tyres on the main gear as it is.
PureCaboose
J160
Hi PureCaboose,
If you are located at YMIG, as your details suggest, you should know that you have no less than two very experienced Jab maintainers at The Oaks, who I am sure can answer your question with the appropriate authority.
Contact me through the personnel system, if you would like to proceed down this path.😈
I am in YMIG, and I use John from the Oak for everything that is beyond me (for now).
Part of owning my own plane is expanding my knowledge and experience. In the technical manual there is no spacer, so i am curious as to why it is there, and who put it there now that I think of it as the plane has been L2 maintained to date.
Building a platform/brace for the engine hoist so I can lift the wing to get the gear off. New brake disks to go on and balance the very much out of balance wheels.
If I can't work it out, I will call John. I though I would asks here to what knoweldge there was. My bad.
PureCabosoe
PureCabosoe
You could send images to Jabiru and ask about this, as if you need any other parts they can be sent with the rubbers. Would be a shame if you need two postage’s and await a second delivery. Great that you are getting to understand your aircraft’s build. Let us know what you find out. Cheers.
PS never know may have only had an over length bolt. If so you will need a correct length one.  Just a guess.
Edited by Blueadventures
PureCabosoe
ALL good!
There was a wing lift devise,  at The Oaks, a few weeks back, being used for the very work you describe.😈
