pete duncan Posted September 8, 2014 Share Posted September 8, 2014 When the time comes to replace the water hoses on my 912 ( engine and radiator ) can I use good quality hose from an auto parts supplier or similar , hydraulic hose from enzed /pirtek etc. Who makes a good quality fuel hose. These are going in a Foxbat LS . Thanks ,Pete. Link to comment Share on other sites More sharing options...
Downunder Posted September 8, 2014 Share Posted September 8, 2014 I'd be going for a "kit" from one of the US aviation supply companies.... http://www.cps-parts.com/catalog/rtxpages/5yearrubber.php Link to comment Share on other sites More sharing options...
Ultralights Posted September 8, 2014 Share Posted September 8, 2014 floods sell a 5 yr rubber replacement kit, im sure they sell the coolant hoses as well. also, companies like aircraft spruce sell rotax hoses. or you can just get tube from a reputable hose dealer like enzed, as long as it meets the same minimum specs Link to comment Share on other sites More sharing options...
Camel Posted September 8, 2014 Share Posted September 8, 2014 The tank to head return hoses are 17mm and this hose is not usually available in auto parts places as they usually have 16mm and 19mm. The other 25mm hoses are available at auto parts shops. I think I quoted the right sizes as I did mine a while ago. I would buy the kit from floods so you don't pay extra freight as they will supply genuine carb sockets and diaphragms. Then buy the 25mm hose from a auto shop as this hose wasn't in my kit and varies on different installations pending where radiator is mounted. Link to comment Share on other sites More sharing options...
Downunder Posted September 8, 2014 Share Posted September 8, 2014 If your spending more than a few hundred dollars on rotax parts, buy from overseas rotax dealers and you will save plenty.... I buy a few years worth of parts (plugs, filters, etc) and save heaps. Even cheaper if you go halves with a mate.... Link to comment Share on other sites More sharing options...
maulonir Posted September 8, 2014 Share Posted September 8, 2014 I use Mackay hose. P/N HH1752 is a 2 metre roll of straight hose, 17.5mm ID which does all the stright ones and I use CH3752 for the 90 degree hose from the header tank, I by online from ezi auto spares, all up about $40 rob Link to comment Share on other sites More sharing options...
