hyundai Posted April 24, 2015 Share Posted April 24, 2015 I have one thanks. That is good Dazza when it comes to spelling it does not matter unless you are writing a document for the courts.There is a thing on the internet where all the letters in the words are jumble up and asked can you read it, I can because we as humans don't look at the letters in a word to be able to read it. But I will remember the word hydraulic in the future thanks for pointing it out. Link to comment Share on other sites More sharing options...
JEM Posted April 24, 2015 Share Posted April 24, 2015 Just a thought I heard of a Rotax 912 with low power/rpm and it turned out to be a blocked muffler. 1 Link to comment Share on other sites More sharing options...
facthunter Posted April 24, 2015 Share Posted April 24, 2015 While the life of multigrade oils is less in terms of viscosity loss at the short intervals we operate it's not likely to be a factor. I would only use it in the colder climates where it's recommended. If you run the straight 50 take more care with your warm up if a cold start is done in chilly conditions. The "plus" is a camshaft corrosion additive. Helps engines when not being used. Nev Link to comment Share on other sites More sharing options...
jetjr Posted April 25, 2015 Share Posted April 25, 2015 Some sucess being had with sports plus oil too Shell were on board too but has stopped due to the aeroshell dept being bought out. All Au people gone i think It runs much cleaner and prevents deposits, so much so that its recommended NOT to be implemented on used engines as can result on glazing With the std multigrade i have also heard life wsnt very good hence why it was removed as recommended for Jab engines I see CAE have new oil thermostat available Link to comment Share on other sites More sharing options...
Guest Andys@coffs Posted April 25, 2015 Share Posted April 25, 2015 Some sucess being had with sports plus oil tooShell were on board too but has stopped due to the aeroshell dept being bought out. All Au people gone i think It runs much cleaner and prevents deposits, so much so that its recommended NOT to be implemented on used engines as can result on glazing With the std multigrade i have also heard life wsnt very good hence why it was removed as recommended for Jab engines I see CAE have new oil thermostat available I use the shell sports plus in my 3300 on the recommendation of the L4 who does my engine work and because I saw some of the reports written about the oil and the test engine it was running in after it was torn down and analysed for wear after significant use.... That said I have a 19 registered Aircraft and as such things I can do are not available for consideration for others flying LSA, for example..... Link to comment Share on other sites More sharing options...
