Ian lawrence Posted December 20, 2016 Share Posted December 20, 2016 Hi ,I have a Thuster t500 Gemini ,and I have to remove the wings to transport it (about 50k) so I have to remove the wings ,how easy is it to do,are there any traps I should be aware of ?,any thoughts ?...many thanks Ian L Link to post Share on other sites
kasper Posted December 20, 2016 Share Posted December 20, 2016 T500 is not a Gemini but both come off the same. No real tricks but it really is needing two people to do it easily. Easiest to pull the Battons out of the wing Take all the nuts off and leave the bolts in as pins One hold in the tip up while you take the struts off Then pull the root spar bolts and the wing is off Repeat on other side Once you get the wings off you can either fold them in their wing skins or move them as ladder wings. If your are folding the wings down inside their skins undo all zips and be careful of skins not getting caught and torn. When moving the wings just be careful the lift strut pickups are not rubbing on skins or get damaged/bent. 1 Link to post Share on other sites
