Timbgy Posted April 13, 2013 Share Posted April 13, 2013 Can anyone tell me if the temp of the 2 stroke oil entering the engine will make any difference to performance. This is on a 582. Link to comment Share on other sites More sharing options...
Doug Evans Posted April 13, 2013 Share Posted April 13, 2013 Can anyone tell me if the temp of the 2 stroke oil entering the engine will make any difference to performance. This is on a 582. What do u mean are u premix or auto lube ? The prelude system works at normal temp No heating required Premix just mix oil in fuel .... Link to comment Share on other sites More sharing options...
frank marriott Posted April 13, 2013 Share Posted April 13, 2013 Good weather now Doug, have you picked up your aircraft yet? Link to comment Share on other sites More sharing options...
Doug Evans Posted April 13, 2013 Share Posted April 13, 2013 Good weather now Doug, have you picked up your aircraft yet? No mate have to head south too a Ulysses AGM at marybough in the morning will be there till next Sunday. Then if the weather permits will be heading north to pick up the plane . On Monday / Tuesday. Link to comment Share on other sites More sharing options...
Guest Maj Millard Posted April 13, 2013 Share Posted April 13, 2013 Doug, Start of good weather just around the corner and Old Station bit more than a month away, you need to get some NM under your belt in that bird.......Maj.... Link to comment Share on other sites More sharing options...
Guest Maj Millard Posted April 13, 2013 Share Posted April 13, 2013 Timbgy, In answer to your question...no shouldn't make a hell of a lot of difference except if it was real cold, which could thicken it and cause it not to flow adequetly in an auto-lube set-up.....................Maj... Link to comment Share on other sites More sharing options...
Timbgy Posted April 14, 2013 Author Share Posted April 14, 2013 Thanks Maj Link to comment Share on other sites More sharing options...
