348 Posted August 10, 2013 Share Posted August 10, 2013 Hi is there some one who could please help with a bit of theory on the concept of under-banking during a descending turn and how the inner wing into the turn has a higher angle of attack creating lift to counter the lift created by the higher speed of the outer wing. Link to comment Share on other sites More sharing options...
Head in the clouds Posted August 10, 2013 Share Posted August 10, 2013 Glad you reminded me, I like to watch Turn Smart regularly, hope you get something good from it too - https://www.youtube.com/watch?v=xwrfEsCiltc Link to comment Share on other sites More sharing options...
planesmaker Posted August 10, 2013 Share Posted August 10, 2013 That is an excellent video thanks for that. Never stop learning. Tom Link to comment Share on other sites More sharing options...
348 Posted August 10, 2013 Author Share Posted August 10, 2013 Thanks for the great video. Link to comment Share on other sites More sharing options...
facthunter Posted August 11, 2013 Share Posted August 11, 2013 Is the term under banking used often? It WAS called holding aileron ON or OFF. ( The stick or wheel is displaced). While this is taught in aviation theory early, the practical effect is that you don't really know you are doing it when you have been flying for a while. You make the plane do what you want it to and use whatever control input is necessary to make that happen. Balanced flight with ball in centre is important at some critical times. IF the ailerons were required to be displaced in S&L your plane would be misrigged and should be checked or the rudder/ engine offset is wrong. Engine power changes in some planes will change the rudder requirement and if this is not compensated for the ailerons will be required. Sometimes this effect is greater than the climbing and descending effect on wing angles of attack.. Nev Link to comment Share on other sites More sharing options...
