puddles_7 Posted January 26, 2014 Posted January 26, 2014 Hi Guys, There has been some discussion on these forums about CAMit mods for Jabiru engines and CAMit are advertising Aero engines on their website. What I would like to know is under what circumstances can the CAMit engines or their modified parts be used in a current Jabiru airframe. Does this require a registration modification or does it require a signoff by an approved person? Puddles_7
deadstick Posted January 26, 2014 Posted January 26, 2014 Puddles, I asked the same question to the powers that be! For a C model factory built you can fit the exact same cammit engine parts and remain 24 rego'd. The D models are different due to the factory being the engineering authority. For a 19 rego'd aircraft you can fit whatever you like.
Russ Posted January 26, 2014 Posted January 26, 2014 So......I can fit camit components into my 24 reg, but cannot fit a whole camit engine into my 24 reg ....?? ( 24 C model )
Oscar Posted January 26, 2014 Posted January 26, 2014 Quote So......I can fit camit components into my 24 reg, but cannot fit a whole camit engine into my 24 reg ....?? ( 24 C model ) Russ, I understand that 'C' models can be modified with an EO from a Part 21M engineer that is accepted by CASA. If you can wait for a little while, I think you'll find that a whole lot easier for a complete engine than right now as CAMit proceeds with testing etc. and their engine becomes a 'spec.' unit - CAMit are still developing their final specification as a result of the results of test flying being undertaken at the moment (or certainly was when I was last there in October last year). I believe that there are around 8 CAMit-modded engines out there gathering hours, and CAMit's test and development programme is still somewhat of a work-in-progress with new stuff being tried and proven all the time.
