Tim, can you give us a description of your system....are you just pumping it into the exhaust outlet pipe, like they do on ag planes ?..
It's called the " holy smokes system" from Bear Perkins. USA" designed for ultralight use - specifically rotax 2 strokes.
Perkins powered parachutes
Guest Maj Millard
Thanks Tim.....
Still need a video Tim!!!!!!!!!
Lol will do. Wx crap at present, next flight will film smokey
The smoke doesn't actually burn. There's no oxygen left in the stuff from the engine. It's vaporised by the heat IF some of it burns in the pipe, it will be blacker. IF it starts to burn outside the pipe YOU might be blacker.
I recently saw a pilot smoke the entire strip. The next aircraft nearly could not land as it was getting dark. No wind.... Nev
I'm still yet to fabricate an injector as per advice which improves vaporisation by almost 50%( so I'm told?) ,but I'm pretty happy with the system set up as is.
Figures crossed for dawn patrol in the morning With gopro attached
Will edit vid ASAP but here's a pic
Making doughnuts in the sky
I have a safety switch for smoke (you have to hold it on for smoke) also wired via relay direct to engine ( rectifier reg)as per specs For safety ,so it won't work if engine stops.
Happy days
Looking good
Yes thank you , although I could do with a shave! , so what do you think of the smoke?008_roflmao.gif.692a1fa1bc264885482c2a384583e343.gif008_roflmao.gif.1e95c9eb792c8fd2890ba5ff06d4e15c.gif007_rofl.gif.8af89c0b42f3963e93a968664723a160.gif
It looks like you've taken some hits to the engine. You might be up for a forced landing behind enemy lines. Curses to the RED BARRON
Found this.... I can get 20 ltr drum of paraffin oil from the fodder store$$?
Might be worth a go , prepared to pay a lil extra than trany fluid for an environmentally friendly burn.
If you doing skywriting be careful with things like... HAPPY BIRTHDAY CLINT Nev
Took me a little while! Lol
Lol , need to wait for calm afternoon. The missus doesn't get up early enough for morning filming !
