    Register Log in
Sign in to follow this
Lyndon
Lyndons Savannah VG Thread
No I haven't found any plate yet. I'm just sorting the wiring so it misses the cables etc.
The manual shows all sorts of extra prices on the fuse which arnt in the parts list. So I will chase up the wiring the extra parts and prime them before I rivet up the fuse. If any one has a pic of their loom it would be a great help.
Lyndon
Now jumping a step. If I close up the fuse. Including the cargo area wiring for the trim and I have the rudder cables. I will be able to fit the elevator cables ok afterward s
Lyndon
You access the cables through the hole in the bottom. The elevator cables have a metal sliding strip for adjustment. You can leave the elevator cables hanging out the back as ou can get to them from the inside ok
So what your saying is I can go ahead and rivet up the fuselage skins and leave the elevator cables for a later date when I fit the tail. ??
Thanks Lyndon
Well the cables should be attached to the elevator as one goes through the front of the stab. You just drag them through when you fit the stab..and you join them to the stick belcrank through the bottom opening
Bloody manual. Parts list for the rear fuselage. All primed and ready to go. Then during assembly all these other parts are required. If I went by the manual you button up the skins then you can't fit these angulars. Luckily I haven't riveted it all up. But I now need to set up and prime again. No economy of scale.
Lyndon
Bloody manual. Parts list for the rear fuselage. All primed and ready to go. Then during assembly all these other parts are required. If I went by the manual you button up the skins then you can't fit these angulars. Luckily I haven't riveted it all up. But I now need to set up and prime again. No economy of scale.Lyndon
They're probably used to builders who go a hell of a lot slower than you... 003_cheezy_grin.gif.c5a94fc2937f61b556d8146a1bc97ef8.gif
Thoughts on a 100 hp Rotax out of hours at a flying school. Soft start 2009 all serviced by a lame. Or is second hand to be avoided.
Lyndon
Lyndon
It has probably done 1,500 hours so you will have 500 hours left for you 001_smile.gif.2cb759f06c4678ed4757932a99c02fa0.gif
Front lower hatch fixing support question. What am I missing. How does this work. Is it bent over to catch the lip. A rod installed to make a hinge. Nothing in my manual except rivet it the hatch ???
Lyndon
No bending, no rod, just rivet it on as per the diagram on the page in your photo. The cover will then go on the outside of the fuselage with the riveted strip inside the fuse. Cleco it first and try it and you will work it out.
Regards,
Bob
Ta. The fuse is a bit of work. Alignment of rivets seems to be a job and a half. In a day or two hopefully it will be done.
Lyndon
What am I missing. .... Nothing in my manual except rivet it the hatch ???
Lyndon
You seem to be having more than average trouble understanding the manual. The manual has copped a lot of criticism but it is better than that.
I will give you two bits of advice. Read the manual for the next section you expect to be building the night before you start, you will digest it before you need it that way. The other thing is that they tend to have the explanation on one page BUT the picture or diagram on the facing page usually is the diagram for the page before. So when you are looking for clarification from a diagram, turn the page and you will likely find what you need.
Will do. The fuse is just miss behaving as all the rivets don't line up. Especially the A and B rib. I want it cleacoed before rivets.
Lyndon
Are you using a podger to work them into the right spots?...you need a 1/8 and a 5/32 one. this makes it a lot easier
Two of each is three times better , working either side of the offending cleco until they are click out to full extension.
No never heard of it. But I'm pretty sure of what it will look like. Will get onto it .
Thanks Lyndon
See post #116
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
