19 and 25 rego numbers on plane
I see that most 19 and 24 etc rego numbers are on the tail plane and thus fairly small. But the equivalent in the US canada etc are on the side of the fuselage and so quite a bit larger. Is there any legal reason you couldn’t put your 19 rego number on the fuselage side?
RAAus tech manual requires either both sides of fuselage or on outer side of tail and now specified minimum sizes that will preclude most new reg ever using the tail so you’ll see many more moving to fuselage sides.
