Young kid builds and flies amazing 'Magnus Effect' plane
dominicm
I was quite amazed by this. I had never seen or even heard of a Magnus Effect plane until Finley showed up with what looked like an upside down lawn mower. He's a very articulate kid and talked me through the physics of how this thing works. It doesn't just work...it flies really well...and he built it totally from scratch. Quite looking forward to seeing what he comes up with next.
Needs higher mast to give more pendulum stability.
NO.. "pendulum stability" will not help.. You would just end up with big lateral dynamic oscillations.. lateral divergence is a "dynamic stability" problem which can only be solved with damping or the equivalent of dihedral producing opposite roll with side-slip (like a big central fin above the rotor) or effective roll controls.. The gap in the middle is also a big lift killer..
Strangely the video of the model at the top of this thread clearly uses pendulum stability for roll stability and a rear rudder for direction.
So I’d disagree
Strangely the video of the model at the top of this thread clearly uses pendulum stability for roll stability and a rear rudder for direction. So I’d disagree
I was only referring to the Russian towed thing.. model is different for a number of reasons..
