skippydiesel Posted July 8 Posted July 8  Does reflexing the flaps, by a few degrees (1-6) have a;  significant improvement to cruise speed ? detrimental effect on stall speed WITH flap ?  😈
Thruster88 Posted July 8 Posted July 8 Significant improvement in speed, no. If there was every manufacturer would be doing it. Maybe it is some times used to correct a design that is not quite right.  Change in stall speed with full flap? I presume you mean if there is 5° reflex your max flap is reduced from say 40° to 35°. The last bit of flap travel does little for stall speed reduction, it just adds more drag so negligible change in stall speed. 1
Freizeitpilot Posted July 8 Posted July 8 A good thread on reflexed flaps from way back in 2014.  https://www.recreationalflying.com/forums/topic/23881-reflex-flaps-and-ailerons/ 1
skippydiesel Posted July 8 Author Posted July 8 (edited) 2 hours ago, Freizeitpilot said: A good thread on reflexed flaps from way back in 2014.  https://www.recreationalflying.com/forums/topic/23881-reflex-flaps-and-ailerons/ It was pretty inconclusive back then, with about equal for & against (assuming against includes those who felt no significant benefit/effect).  A few commentators seemed to think that the European small aircraft manufactures supported/included this feature in their aircraft (I was one).  I would ask - If this feature works for the EU why not AU & US (etc)? That the 11 years since that debate may have found some more evidence for & against? Could the main wing aerofoil have an influence on reflex being a significant benefit ? 😈 Edited July 8 by skippydiesel
