Roscoe Posted June 11, 2014 Share Posted June 11, 2014 Hi again folks. I noticed some Blue Avgas stains around the area where the chain from the drain plug meets the Wing Root on LH Wing today. Noticed on first flight after Refuelling to full when putting Aircraft away. Was careful not to spill fuel and only on LH side. Have advised Jabiru as Aircraft is new and they always respond quickly but thought I would ask if anyone else has noticed this. Appreciate your help guys. Cheers Roscoe Link to comment Share on other sites More sharing options...
jetjr Posted June 11, 2014 Share Posted June 11, 2014 if you refill too full the excess can drain down the ear of the wing to the root, drains in behind flap so cant br seen until reaches cabin maybe fuel expanding with heat or maybe like mine the aircraft leans to one side in the hanger, fuel can cross feed from one side to the other too. Always could be a leak of some sort Link to comment Share on other sites More sharing options...
Roscoe Posted June 11, 2014 Author Share Posted June 11, 2014 Thanks JR. Appreciate reply. Link to comment Share on other sites More sharing options...
Guest Andys@coffs Posted June 12, 2014 Share Posted June 12, 2014 Yep, on my J230 if I fill too full it leaks out and on occasion I even have had folk on the ground radio me that there is fuel leaking in flight on T/O........If I put 1L less in each side I have no issue Andy Link to comment Share on other sites More sharing options...
Roscoe Posted June 12, 2014 Author Share Posted June 12, 2014 Andy do you mean it leaks from the fuel cap and runs underneath to the wing root? Link to comment Share on other sites More sharing options...
Guest Andys@coffs Posted June 12, 2014 Share Posted June 12, 2014 Not sure exactly where it leaks from but it does find its way down to the wing root, it doesn't necessarily seem to flow out onto the top of the wing....Never went looking in huge detail, just know that if the fuel is up over the holes in the metal circle that the filler fits into it will leak.. With the blue die you can generally find where it has been, but not always Andy Link to comment Share on other sites More sharing options...
Oscar Posted June 12, 2014 Share Posted June 12, 2014 Leaks of petrol into the general wing internal area are not good -the foam ribs are not petrol resistant. Link to comment Share on other sites More sharing options...
Roscoe Posted June 12, 2014 Author Share Posted June 12, 2014 Will keep a close eye on this and keep you all updated, thanks . Link to comment Share on other sites More sharing options...
AVOCET Posted June 12, 2014 Share Posted June 12, 2014 I've repaired jabiru wings that leak fuel when filled to the brim , it's usually the fuel cap carriage hasn't been flocked into the tank properly when built . easy to fix by wiping some resin & flock up & under with your finger . and I'm pretty sure the high density foam in the jabiru wet wings isn't effected by petrol . not like the old poly styrene wings cheers mike Link to comment Share on other sites More sharing options...
Roscoe Posted June 12, 2014 Author Share Posted June 12, 2014 I've repaired jabiru wings that leak fuel when filled to the brim , it's usually the fuel cap carriage hasn't been flocked into the tank properly when built .easy to fix by wiping some resin & flock up & under with your finger . and I'm pretty sure the high density foam in the jabiru wet wings isn't effected by petrol . not like the old poly styrene wings cheers mike Mike thanks, never heard the word flock before, can u elaborate pls Link to comment Share on other sites More sharing options...
AVOCET Posted June 12, 2014 Share Posted June 12, 2014 Mike thanks, never heard the word flock before, can u elaborate pls the cotton flock (powder) is mixed with the resin to form a past that doesn't run cheers mike Link to comment Share on other sites More sharing options...
Roscoe Posted June 12, 2014 Author Share Posted June 12, 2014 the cotton flock (powder) is mixed with the resin to form a past that doesn't runcheers mike Thanks Mike Link to comment Share on other sites More sharing options...
jetjr Posted June 12, 2014 Share Posted June 12, 2014 In mine the excess fuel leaks out fill cap, runs backwards to top of flap cavity, then down to fuse, sometimes see some on flap itself. O rings in filler caps (theres 2x in there) need regular replacement Just fill a bit less Every so often the blue stain wont rub off easily, but it fades pretty quickly Link to comment Share on other sites More sharing options...
Roscoe Posted June 12, 2014 Author Share Posted June 12, 2014 In mine the excess fuel leaks out fill cap, runs backwards to top of flap cavity, then down to fuse, sometimes see some on flap itself.O rings in filler caps (theres 2x in there) need regular replacement Just fill a bit less Every so often the blue stain wont rub off easily, but it fades pretty quickly Yep thanks again. Will put less fuel in next time and see hw it goes. Cheers for now Link to comment Share on other sites More sharing options...
Russ Posted June 12, 2014 Share Posted June 12, 2014 A good waxing protects that area. ( "wicked" top stuff ) Link to comment Share on other sites More sharing options...
Roscoe Posted June 13, 2014 Author Share Posted June 13, 2014 A good waxing protects that area. ( "wicked" top stuff ) Russ can this be bought in Aust?, I see on their website it's a US product. Thanks Link to comment Share on other sites More sharing options...
Russ Posted June 13, 2014 Share Posted June 13, 2014 Yea, can be hard to find, best way....truck spares/ accessories place. ( lot of drivers swear by it ) Maybe........super cheap...autobarn. If not......I have a spare bottle, I will sell it to you. ( $16 + post ) Link to comment Share on other sites More sharing options...
AVOCET Posted June 13, 2014 Share Posted June 13, 2014 Russ can this be bought in Aust?, I see on their website it's a US product.Thanks listen guys , waxing fibre glass isn't a good idea , the wax and such will over time work it's way through any pinhole or slight crack in the paint and the paint itself and "can"make any future repair or repaint difficult to near impossible . I know you can use wax & grease remover , but that won't remove the potential build up in and below the gelcoat mike Link to comment Share on other sites More sharing options...
