Geoff13 Posted June 23, 2014 Share Posted June 23, 2014 What is the significance of the different prefixes on registration numbers please? Link to comment Share on other sites More sharing options...
dodo Posted June 23, 2014 Share Posted June 23, 2014 It sort of tells you which bit of legislation the aircraft is registered under. However, it only sort of tells you... for instance, 24 prefix is factory built, but could be either LSA or type-certified. dodo Link to comment Share on other sites More sharing options...
M61A1 Posted June 23, 2014 Share Posted June 23, 2014 What is the significance of the different prefixes on registration numbers please? They are different categories. Just off the top of my head: 10 = an aircraft built under ANO/CAO95.10 25 = 95.25 (factory built) 55 = 101.55 19 = 95.55 amateur built 24= 95.55 LSA 32 = 95.32 (weight shift) Link to comment Share on other sites More sharing options...
Geoff13 Posted July 13, 2014 Author Share Posted July 13, 2014 Well I have been reading us much as I can about this but it really is confusing. I looked at a 28 registered plane that has a claimed MTOW of 544 Kg but by my reading it cant go over 450kg. Am I missing something. Is there something that shows the weight for a specific aircraft. Then there is a similar aircraft with 55 reg that has a claimed MTOW of 500 kg. Help? Link to comment Share on other sites More sharing options...
M61A1 Posted July 13, 2014 Share Posted July 13, 2014 If I am reading correctly, the old CAO 101.28 (now covered by 55 reg), had a MTOW of 544 kg and was 51%rule amateur built, but the stall speed was different to the current 55 rules. 1 Link to comment Share on other sites More sharing options...
