derekliston Posted August 10, 2014 Share Posted August 10, 2014 Does anyone on this forum have any expertise with Dynon Skyview? I am having big trouble trying to get the fuel pressure reading correctly and as helpful as Dynon are, it's still an unwieldy way of doing things. Basically I have a Kavlico 0 -30psi transducer installed and the Jabiru engine driven fuel pump should produce between 0.75 and 3psi but I am getting a reading of around 17psi which is obviously erroneous since the carby is not flooding! Anyone have any ideas? Link to comment Share on other sites More sharing options...
Camel Posted August 10, 2014 Share Posted August 10, 2014 Was looking out of interest, worth a look. http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1341939117/4 Link to comment Share on other sites More sharing options...
jetjr Posted August 10, 2014 Share Posted August 10, 2014 Fuel pressure in jab is very low and measuring these low pressures is plain difficult Often sensors actually only read from say 5-30 psi and your right down the bottom end of the scale Add to this the strong pulsating caused by fuel pumps. Link to comment Share on other sites More sharing options...
crashley Posted August 10, 2014 Share Posted August 10, 2014 Hi I have a skyview and the fuel pressure reads ok have you selected the correct sensor in the skyview setup also is there a restrictor in the pressure sensor line to dampen the pulses and finally the best method of fault finding may be to connect in an actual guage to compare readings Where are you located Link to comment Share on other sites More sharing options...
Downunder Posted August 10, 2014 Share Posted August 10, 2014 Jakej on this forum would be the Australian expert. PM him here or on the Dynon forum. If you can't get hold of him, PM me for his number. 1 Link to comment Share on other sites More sharing options...
derekliston Posted August 10, 2014 Author Share Posted August 10, 2014 Hi I have a skyview and the fuel pressure reads okhave you selected the correct sensor in the skyview setup also is there a restrictor in the pressure sensor line to dampen the pulses and finally the best method of fault finding may be to connect in an actual guage to compare readings Where are you located Yes I have the correct sensor selected, checked that after inquiring with Dynon, also have a restrictor in the line. I know without a gauge that the pressure is Ok because the carby isn't flooding, if the pressure was as high as it reads it would lift the float needle and flood. It might be necessary to use a gauge to double-check though. I am in Ipswich Qld, aeroplane is on the Coominya airstrip. Where are you? Link to comment Share on other sites More sharing options...
derekliston Posted August 14, 2014 Author Share Posted August 14, 2014 Problem solved with the assistance of Jake Jansen, turned out that earthing the sender to the firewall was not a good idea! Changed the earth connection to one of the black skyview wires solved the problem. Big thanks to Jake, one step closer to flying. 2 Link to comment Share on other sites More sharing options...
