Nachem Posted August 16, 2015 Share Posted August 16, 2015 Hi There, we are now in a building process of our new Nynja. wondering about : 1. Servo system for Aileron & Elevator trimmer. which one to buy ? 2. Battery for the Rotax 912uls 3. Propeller Any advise will be appreciated. Thanks, Nachem Link to post Share on other sites
Nachem Posted August 16, 2015 Author Share Posted August 16, 2015 Hi There, we are now in a building process of our new Nynja. wondering about : 1. Servo system for Aileron & Elevator trimmer. which one to buy ? 2. Battery for the Rotax 912uls 3. Propeller Any advise will be appreciated. Thanks, Nachem Link to post Share on other sites
Guest Maj Millard Posted August 16, 2015 Share Posted August 16, 2015 Best recommendation for battery would be a standard lead- acid around 18-20 amps. Do not buy one utilising new Lithium ion technology as they won't be compatible with the 912 charging system. Also contact 'Blueadventures' on this site as he is about to complete his Ninja project. A three blade CF prop would suit the Ninja well. Link to post Share on other sites
skeptic36 Posted August 16, 2015 Share Posted August 16, 2015 Best recommendation for battery would be a standard lead- acid around 18-20 amps. Do not buy one utilising new Lithium ion technology as they won't be compatible with the 912 charging system. Also contact 'Blueadventures' on this site as he is about to complete his Ninja project. A three blade CF prop would suit the Ninja well. Lithium ion are too unstable for any aircraft, no matter the charging system. Lithium Iron is fine and is much lighter than lead acid. 1 Link to post Share on other sites
skeptic36 Posted August 16, 2015 Share Posted August 16, 2015 Best recommendation for battery would be a standard lead- acid around 18-20 amps. Do not buy one utilising new Lithium ion technology as they won't be compatible with the 912 charging system. Also contact 'Blueadventures' on this site as he is about to complete his Ninja project. A three blade CF prop would suit the Ninja well. Lithium ion are too unstable for any aircraft, no matter the charging system. Lithium Iron is fine and is much lighter than lead acid. Link to post Share on other sites
hihosland Posted August 17, 2015 Share Posted August 17, 2015 My 10 yr old Skyranger V Max still has the original Odyssey battery My trim works well with a simple Bowden cable set up, adding a servo seems to me to be unnecessarly complicated Kit was built with 80hp Rotax and a Keiv prop with a brass leading edge, operations from paddocks and gravel airstrips severely damaged the leading edges to the point where the epoxy suffered and the edges were beginning to separate. Replaced with Kool prop with stainless leading edges riveted to the blade and a much more serviceable result. Probably not very relevant to your bigger motor and different wing. I suspect that the most useful addition that could have been made to my installation would have been an oil thermostat. best wishes with your build David h 1 1 Link to post Share on other sites
hihosland Posted August 17, 2015 Share Posted August 17, 2015 My 10 yr old Skyranger V Max still has the original Odyssey battery My trim works well with a simple Bowden cable set up, adding a servo seems to me to be unnecessarly complicated Kit was built with 80hp Rotax and a Keiv prop with a brass leading edge, operations from paddocks and gravel airstrips severely damaged the leading edges to the point where the epoxy suffered and the edges were beginning to separate. Replaced with Kool prop with stainless leading edges riveted to the blade and a much more serviceable result. Probably not very relevant to your bigger motor and different wing. I suspect that the most useful addition that could have been made to my installation would have been an oil thermostat. best wishes with your build David h Link to post Share on other sites
Blueadventures Posted August 17, 2015 Share Posted August 17, 2015 Hi There,we are now in a building process of our new Nynja. wondering about : 1. Servo system for Aileron & Elevator trimmer. which one to buy ? 2. Battery for the Rotax 912uls 3. Propeller Any advise will be appreciated. Thanks, Nachem Hi Nachem Steve woods on this forum has an electric trim system fitted to his Nynja. I've installed the Odyssey battery in mine, not yet flown still finishing off, may be heavy by are reliable and last. Re propellor may be best to use whats recommended and available over your way. I have a DUC and the Keiv's and bolly's are popular as well. Also check in your kit about the s/s tabs that are attached to the leading edge and traing edge tubes and the jury struts attach to these; mine were the light material type and the kit also had the newer heavier / thicker material so read the manual and decide if you build with the thicker s/s 90 degree tabs or use hinge eye bolts. I changed mine out for the thicker s/s parts as they allow more standoff away from the wing tubes which allows more distance to the edge of the jury strut bolt holes. Happy building. Mike 1 Link to post Share on other sites
Blueadventures Posted August 17, 2015 Share Posted August 17, 2015 Hi There,we are now in a building process of our new Nynja. wondering about : 1. Servo system for Aileron & Elevator trimmer. which one to buy ? 2. Battery for the Rotax 912uls 3. Propeller Any advise will be appreciated. Thanks, Nachem Hi Nachem Steve woods on this forum has an electric trim system fitted to his Nynja. I've installed the Odyssey battery in mine, not yet flown still finishing off, may be heavy by are reliable and last. Re propellor may be best to use whats recommended and available over your way. I have a DUC and the Keiv's and bolly's are popular as well. Also check in your kit about the s/s tabs that are attached to the leading edge and traing edge tubes and the jury struts attach to these; mine were the light material type and the kit also had the newer heavier / thicker material so read the manual and decide if you build with the thicker s/s 90 degree tabs or use hinge eye bolts. I changed mine out for the thicker s/s parts as they allow more standoff away from the wing tubes which allows more distance to the edge of the jury strut bolt holes. Happy building. Mike Link to post Share on other sites
eightyknots Posted August 20, 2015 Share Posted August 20, 2015 Hi There,we are now in a building process of our new Nynja. wondering about : 1. Servo system for Aileron & Elevator trimmer. which one to buy ? 2. Battery for the Rotax 912uls 3. Propeller Any advise will be appreciated. Thanks, Nachem I wish you well as you build your Nynja over the next few months(?) Link to post Share on other sites
SDQDI Posted August 20, 2015 Share Posted August 20, 2015 I'm a plus 1 for the Odyssey batteries. You can probably find cheaper and lighter but I've never had a problem with their reliability and it is fairly common to hear of people getting ten or more years out of them. Link to post Share on other sites
Downunder Posted August 20, 2015 Share Posted August 20, 2015 http://www.ebay.com.au/itm/ODYSSEY-PC625-DRY-CELL-AGM-BATTERY-12-VOLT-MOTORBIKE-MOTORCYCLE-HARLEY-JET-SKI-/321243729579?hash=item4acb9e4eab Bought one of these. Couldn't beat the price and was significantly more powerful that original at a similar weight. Can't go past the Odyssey. Size depends on your weight allowance/electrical loading. Bigger the better in that regard. Some ULS's running with quite small Odyssey's. Too weak a battery and you risk damaging your engine starter system by turning it over slow. Don't forget cabling. Minimum 16mm2.......more if further from engine. There are charts and calculators for this. Prop. Running a 3B warp drive CF. Nickel leading edge. Value for money but wouldn't consider it anything special or flash. Does the job...... Link to post Share on other sites
