JackieB Posted February 5, 2020 Share Posted February 5, 2020 Hello everyone, Hope you're doing well. I'm just starting to get into flying and have picked up a Thruster T85 (correct me if wrong. From my research it could be a T83. Pics attached) that needed new wing skins. I can use the existing tail skins as templates for the new ones but I do not have wing skins to base them off. Does anyone have any sources where I could get a template from? Any help is appreciated. Cheers, Jack Link to post Share on other sites
Brownie Posted February 5, 2020 Share Posted February 5, 2020 Jack give wingtech a call they should be able to help you out . www.wingtech.com.au Link to post Share on other sites
JackieB Posted February 5, 2020 Author Share Posted February 5, 2020 Thanks for the recommendation. I have been in contact with Wingtech but they do not provide templates. They will only do it in house. I want to be able to do it locally off a template and hopefully save a bit of $ so looking into other alternatives. Link to post Share on other sites
kasper Posted February 5, 2020 Share Posted February 5, 2020 Well wingtech will not lend a template Which is pretty fair in all honesty - it takes a few hours of work and materials to create them even off an old set. BTW It’s a t83 and after the last set of t83 skins I made I didn’t keep my template as I wound up my sail loft so I’m afraid it’s over to anyone else with either the correct span/no of batten pockets that has a template or a set of old skins to lend. Link to post Share on other sites
Deskpilot Posted February 5, 2020 Share Posted February 5, 2020 Didn't I respond to you on the English Microlight forum? Link to post Share on other sites
MadamBreakneck Posted February 8, 2020 Share Posted February 8, 2020 (edited) ... I want to be able to do it locally off a template and hopefully save a bit of $ so looking into other alternatives. It seems like you may be down to making your own template from first principles - at least you have the wing frame and the battens to start from. I suppose it depends on how many $$ you hope to save. However you solve the problem, good luck with it. As I said on the UK forum, it looks a nice little aeroplane. Edited February 8, 2020 by MadamBreakneck Link to post Share on other sites
