Thruster87 Posted May 9, 2011 Posted May 9, 2011 Has anyone found a cheap supplier of loctite 620 10ml bottle and primer. Blackwoods quoted $41.00 approx, Cheers
frank marriott Posted May 9, 2011 Posted May 9, 2011 $48 last week in Townsville - $41 sounds much better
jetjr Posted May 10, 2011 Posted May 10, 2011 It only comes in larger bottle I think, and yep that $45 + is about the price.
Thruster87 Posted May 10, 2011 Author Posted May 10, 2011 The following company from the USA might be an option http://www.rshughes.com/products/079340_62015.html. If enough people want to put an order in maybe Ian could get it via the store .Volume Discount Prices :Loctite® 620™ Retaining Compound; 10ML Bottle Quantity, BOTTLE (BO) Price 1 - 9 $16.82 10 - 49 $12.94 50 - $11.52
Bubbleboy Posted May 10, 2011 Posted May 10, 2011 I will be needing this too so if anyone is going to order a bulk lot, count me in! Scotty
Thruster87 Posted May 13, 2011 Author Posted May 13, 2011 Permatex 27200 appears to be a replacement at half the price at $22.00 delivered on eBay for a 10ml bottle http://www.ebay.com.au/itm/Permatex-27200-Hi-Temperature-Threadlocker-Red-10-ml-B-/320689180602?pt=Motors_Automotive_Tools&hash=item4aaa908fba 61yQtEp-3jS.pdf 61yQtEp-3jS.pdf 61yQtEp-3jS.pdfFetching info...
Modest Pilot Posted May 28, 2011 Posted May 28, 2011 There is also a cheaper Locktite with similar specs available, but beware as the temperature rating is to low. Also the latest 620 containers breathe and have a much longer; if any; use by date.
G-OMER Posted January 10, 2013 Posted January 10, 2013 bondloc 620. this is exactly the same spec as loctite 620 but 1/4 of the price in the uk
old man emu Posted January 10, 2013 Posted January 10, 2013 Hmmm. Might pick up half a dozen bottles while I'm here. OME
facthunter Posted January 11, 2013 Posted January 11, 2013 I TRUST the loctite brand. you put all of one drop on each nut. You don't drink the stuff. Nev 1
