What is the process of installing nav lights on the tips of a J230 wing. Is there a cavity which wires can be passed from the wing root or is it too late once assembled?
Guest Howard Hughes
Don't know about Jabirus specifically, but perhaps through the wing leading edge?
There is a track along the trailing edge where the aileron cable runs. I used some yellow tongue from chipboard flooring to install my lighting cable - wings off.
  • 2 months later...
Guest Mark_hwltt
I did strobe installation on a LSA55/3J , use some yellow / green tongue plastic joiner as a snake but glue some small steel washers to the end first, push the yellow tongue from the cabin following the aileron cable, as the cable gets to the wing tip use a magnet held on the wing skin to guide the end of the yellow the last bit.
Welding magnets are good to use, cover with masking tape to protect wing finish.
Once it pokes into the aileron inspection hole at the wing tip, tape the wire to the yellow tongue and carefully feed and pull back into the cabin.
  Quote
I did strobe installation on a LSA55/3J , use some yellow / green tongue plastic joiner as a snake but glue some small steel washers to the end first, push the yellow tongue from the cabin following the aileron cable, as the cable gets to the wing tip use a magnet held on the wing skin to guide the end of the yellow the last bit.Welding magnets are good to use, cover with masking tape to protect wing finish.
That will work ,
On the 230 wing there are holes in the ribs ,
You don't have to take the wing off ,
At the wing root end ,after drilling a hole in the skin where you position your lights ,you'll
Have to drill a small hole Into the end rib , as this is the only solid rib .
Getting the string down through the wing is not difficult , you need somthing long and thin to attach the string to .
I've joined a couple or three lengths of dowel , but you can use any thing stiff .
Check photo of wing rib holes
This is a 250 wing , the 230 wing is similar
IDE go down the leading edge as there's no restriction all the way down .
  Quote
That will work ,On the 230 wing there are holes in the ribs ,
Cheers [ATTACH=full]23261[/ATTACH]
The holes are called lightening. Most aircraft ribs have them. Used as the name suggests, to lighten the rib.
