Instead of an alternate why not think of it as a possible hybrid.......... I could change from STOL to VTOL and it could also be a limp home function so if you have a primary engine failure it pops up and gives you ten or fifteen minutes.
It would be fun on a single seat setup just for the novelty of it
You may need to carry a lot more fuel to travel the same distance. This neutralises the weight advantage somewhat.
True. As SDQDI says though it'd be a lot of fun with a single seater.
... it pops up and gives you ten or fifteen minutes.
On the engine site they show it set up on top of a Blanik. Engineering a "pop up" cradle that would handle the thrust may be heavy, but then again you don't have to worry about folding props. I'm thinking a jet-powered glider would get some attention at the local club!
  • Caution 1
It's already been done out at Waikerie. There is a glider with 3 x 40lbf Jet Cat jet engines fitted. It has been flying successfully for a couple of years now. Very cool!
