sandman Posted April 10, 2018 Posted April 10, 2018 I have a glass inline fuel filter which I bought from aircraftspruce and think by memory it was a Tempo brand. I need to change the filter and the rubbers seals rather than buy a new unit, anyone know where I can get these parts from, cheers
Blueadventures Posted April 10, 2018 Posted April 10, 2018 Quote I have a glass inline fuel filter which I bought from aircraftspruce and think by memory it was a Tempo brand. I need to change the filter and the rubbers seals rather than buy a new unit, anyone know where I can get these parts from, cheers Hi you can buy replacement folter elements (need to get the correct length - two available and make replacement runbers. Cheers
Pilot Pete Posted April 10, 2018 Posted April 10, 2018 It would be probably be just as easy getting a filter assembly for a twostroke outboard engine from a marine shop. Made specifically to handle twostroke premix and relatively cheap
skippydiesel Posted April 11, 2018 Posted April 11, 2018 Or you could use these little beauties: Hengst H 102 WK (for those who might want an inbuilt elbow, try H 103 WK) Readily available, reputable manufacturer, gauze filter, lightweight, no leaks, cheap, proven, visual inspection, can be cleaned (but why would you), used by my aircraft manufacturer & Mercedesies diesel cars/light commercials.
Riley Posted April 11, 2018 Posted April 11, 2018 Quote I have a glass inline fuel filter which I bought from aircraftspruce and think by memory it was a Tempo brand. I need to change the filter and the rubbers seals rather than buy a new unit, anyone know where I can get these parts from, cheers Whitworths Marine & Leisure (www.whitworths.com.au) sell both the in-line filters (brand??) and 'pack-of-three' replacement filters. Go to their on-line catalogue to ensure that what they have is what you want.
Pilot Pete Posted April 11, 2018 Posted April 11, 2018 Quote Or you could use these little beauties:Hengst H 102 WK (for those who might want an inbuilt elbow, try H 103 WK) Readily available, reputable manufacturer, gauze filter, lightweight, no leaks, cheap, proven, visual inspection, can be cleaned (but why would you), used by my aircraft manufacturer & Mercedesies diesel cars/light commercials. Who sells them?
skippydiesel Posted April 12, 2018 Posted April 12, 2018 Quote Who sells them? Just Google Hengst Australia for distributors, if that doesn't get you what you want, I can help you out from my personal supply. For filter specifications, Google Hengst, when in Hengst web site, search using part number
Pilot Pete Posted April 13, 2018 Posted April 13, 2018 Good o. Just wanted that out there for everyones info. Thanks. Will check out as well for my own use. Cheers... Pete
jangiolini Posted April 14, 2018 Posted April 14, 2018 Hi only one thing to add to this thread and that is DONT use paper element filters make sure the element is nylon mesh if not you run a very high risk of blockage due to water which will trap on the oiled paper filter Dont ask how I know!!! Regards.. John.
jangiolini Posted April 14, 2018 Posted April 14, 2018 Hi Pete yup I meant that just didnt explain it well:oh yeah:
