Parry Posted 23 hours ago Posted 23 hours ago On 04/08/2025 at 9:54 PM, skippydiesel said: Thanks OneTrack, "Found his post, it was in March, he has 17.5mm Mackay hose." Now that you mention it, I do have some vague recollection. Two points; I will never fit a slightly overlarge hose but will, if needs be, try a slightly small eg 16.5mm ID. Reason being, a slightly small ID will seal against the spigot, fare better than a slightly large ID. If aged memory serves there were questions about the age of this hose - may have been around the time that I found out "rubber" hose actually has a shelf life. 😈 Has nobody measured the spigots? They are all 18mm OD. A 16mm ID hose will be a very tight fit given the barb OD is 19mm 1
skippydiesel Posted 22 hours ago Posted 22 hours ago 7 minutes ago, Parry said: Has nobody measured the spigots? They are all 18mm OD. A 16mm ID hose will be a very tight fit given the barb OD is 19mm Confession time: No I have never measured the spigots (oil/fuel/coolant) just gone with the Rotax specification - my error. It will be a few years (about 2 ) before I get the chance to measure the spigots but will try & remember to do so. Just be a bit careful - some spigots , on the same system, are a diffrent OD. A 16.5mm ID hose should fit a 17 mm OD spigot but as you say, asking a bit much if its actually 18/19mm. My observation still stands - never go for a larger ID hose (even by a little) than the spigot OD - you will be trying to get the clamp to do the sealing for you, rather than the hose/spigot interaction..😈
danny_galaga Posted 19 hours ago Author Posted 19 hours ago On 05/08/2025 at 6:28 PM, Moneybox said: Yes Skippy, I'm pretty sure I bought a couple of 90° hoses but I can't find the invoice. I bought four of these 25mm hoses as well. If Sandra finds the invoice I'll post the list but anything not marked for the plane has just gone into a file of assorted invoices never to be seen again. Obviously it varies between different setups, but for inspiration this is my list of hoses for my Bushcat 03-0010 as per moneybox 01-0007 02-0951 x 2 (datsun 120y) all of these were cut to suit
