skippydiesel Posted September 9, 2024 Posted September 9, 2024 I seek your comment/recommendations on a 12V charger, that will supply a mini iPad (Lightning / USB A ) and a hand held (mounted) GPS navigator (dedicated cigar style male plug).  The two devices are to be connected to "ship" power from TO - Landing (anything from 1 - 4 hrs at a time)  I have a single 12V female "cigar" plug available.  I would like a single adapter to supply both from the above female  The adapter shown, seems to have all the right features (Amazon, currently unavailable) https://www.amazon.sa/-/en/UGREEN-Charger-Cigarette-Charging-Compatible/dp/B086DHWB8Z - what think you?  If possible, I would like a system that "shuts down" or reduces amps , when iPad has a full charge and /or the adapter reaches a high (?) temperature . The GPS male plug already has this.    Â
Freizeitpilot Posted September 9, 2024 Posted September 9, 2024 Charger with CO detector  It ain’t cheap, but it has a unique feature.
skippydiesel Posted September 9, 2024 Author Posted September 9, 2024 Very nice Freizeitpilot BUT need the cigar/cigarette lighter female plug for GPS.  Already have two CO detectors in the aircraft - one on all the time (has the ability to record max ppm) and one I keep forgetting to charge up.😈  Found the above charger, instock, for $23 from i-Tech,  https://www.i-tech.com.au/acbugn60712-ugreen-60712-84w-dual-port-car-charger-space-416314.html
Red Posted September 9, 2024 Posted September 9, 2024 I've used this one https://www.amazon.co.uk/Garmin-Charger-iPhone-Smartphones-Tablets-Black/dp/B00EKFH2VG It seemed pretty clean, dont remember interference from it, as bloke above alludes many are noisey as feck I use a Charge4 unit wired direct to 12v now 1
skippydiesel Posted September 9, 2024 Author Posted September 9, 2024 The RF noise thing is real however on my last aircraft I had at least three diffrent automotive plugs going and never had any interference. - just luck I guess. 1
coljones Posted September 15, 2024 Posted September 15, 2024 go down to JB HiFi and check out the range.
skippydiesel Posted September 15, 2024 Author Posted September 15, 2024 (edited) 3 hours ago, coljones said: go down to JB HiFi and check out the range. Did just that - nothing that had a male/female cigar lighter & USB as per the UGREEN 60712 above. Â Have purchased the UGREEN 60712 ($23 + delivery)- yet to test/try. Edited September 15, 2024 by skippydiesel
