Underwood Posted Wednesday at 05:49 PM Posted Wednesday at 05:49 PM Having moved my Oil cooler to a position that allows its own air intake instead of piggybacked behind the Coolant radiator, I now have the opposite problem of over cooling the oil. cant get max above 80c so will have to blank some of the oil cooler probably use neoprene wrap...not a problem But allong with the low max temps its also taking ages to reach temp before flying so I'm gonna fit a thermostat. (thermostasis unit) Was just wondering do any of you guys fit them?, or are your ambient temps high enough that warm up is hardly ever a concern? 1
FlyBoy1960 Posted Wednesday at 10:06 PM Posted Wednesday at 10:06 PM They work great, i think i still have a new one laying around somewhere. Let me look. 1
facthunter Posted Thursday at 12:24 AM Posted Thursday at 12:24 AM Watch how you PLUMB it. It must not impede the Oil flow. It's also something else to go wrong. Nev 1
PapaFox Posted Thursday at 12:33 AM Posted Thursday at 12:33 AM We just cover half of the oil cooler in winter and accept the upto 10 mins from start to wheels up as a good time for the rest of the motor to warm up evenly and by ready for the cold air charge that comes with flying speed 1 1 1
IBob Posted Thursday at 01:00 AM Posted Thursday at 01:00 AM I bought an auto one (not Thermostasis), have seen them on Rotaxes, but decided not to instal it as they can fail closed: that is fail in the radiator bypass position. If installing one I would want to check the fail position. 1
skippydiesel Posted Thursday at 01:43 AM Posted Thursday at 01:43 AM 7 hours ago, Underwood said: Having moved my Oil cooler to a position that allows its own air intake instead of piggybacked behind the Coolant radiator, I now have the opposite problem of over cooling the oil. cant get max above 80c so will have to blank some of the oil cooler probably use neoprene wrap...not a problem But allong with the low max temps its also taking ages to reach temp before flying so I'm gonna fit a thermostat. (thermostasis unit) Was just wondering do any of you guys fit them?, or are your ambient temps high enough that warm up is hardly ever a concern? I have one, never used - came with the aircraft. I can only sympathise with those that must endure long cold winters - living near Sydney, Australia, I enjoy a more moderate environment. I still "blank" off part of my coolant radiator & oil cooler when day temperatures routinely go below 25C. After much trial/error I arrived at a good compromise blanking, which I have photographed for future reference. In Cruise I have Oil temp. 90-95C. Coolant/CHT 90C. Climb OUT 100-105C. I find that the engine warm up period (Oil -50C) is well spent on checks, review of plan, etc I use adhesive backed refrigeration aluminium tape. Easy to cut & apply - can leave a residue when removed. Residue responds to most hydrocarbons. Reasons for use - Engine operated in seasonally very cold climates eg. N. America, UK, N Europe etc Speeds warm up. Reduced fuel consumption & frustration. Certainly important in cold climate opps but more of a perception benefit, in warmer climates May maintain even engine temperatures on descent - assist with carburettor ice prevention (if fitted) Reasons against - Significant added complexity = more to go wrong = heightened risk. From memory, at lest 4 additional joins in oil supply hose. All things mechanical will fail. Increased weight. Probably a minor concern however every minor increase adds up. Cost. Depending on arm length & depth of pockets, may or may not be an issue.😈
